2204 fuel filter
/ 2204 fuel filter #1
scott1440
kioti lb2204
I have an lb2204, which they apparently don't make parts for anymore. I would like to replace the fuel filter on the bowl (which I JBed to keep it from leaking), but other than buying a whole new fuel bowl assemby that fits a LB1914 (which kioti stilll makes parts, and filters for) just to replace the filter. I havent been able to come up with a solution for. does anyone know of another bowl and filter that would fit on the LB2204? shoud I go with a kubota or other make to get a fuel bowl assembly from? after the last time I had to get a part for the 2204 from the dealer and having to use a 1914 part for,well.... lets just say that the steering colum "mostly" fits.
/ 2204 fuel filter #2
The LB2204 and LB1914 takes the same fuel filter.
I have tons of the filters on my shelf. $5.49 each
I also have a complete fuel filter assembly on my shelf $33.00
Just a little note to you.
The Kioti CK20 and the Bobcat CT120/122 all run the same filter. The housing looks the same but the outlet side on the ck series has a 90 degree elbow where as the lb has a straight.
/ 2204 fuel filter #3
If Rick Wallace advised they are the same, he would know. Give him a call. Very knowledgeable, used to work on and sell Kioti but Bobcat now, and friendly to talk to along with his entire staff. He'll mail or UPS parts quickly if needed.
It's nice to see you're still here Rick. I hope all is good in NorthEastern PA.
/ 2204 fuel filter #4
Im still here....
Haven't had a lot of free time this year.
We have been ungodly busy.
I ended up hiring 2 more employees this year.
We are still back logged!
I still check this sight out almost every day even though I dont post.
/ 2204 fuel filter #5
I have a Bobcat CT120 I changed the fuel filter element and now it is leaking. I tightened it up and the leak continues. Any suggestions before I start a fire?
Next,I was applying the parking brake I heard a metallic clunk and the parking brake is no longer working. What do you think happened?
/ 2204 fuel filter #6
My 12 yr young LB1914 came with a bowl for a shorter and narrower filter. My illustration has a spring at bottom of bowl (or "Pot" as Kioti listed it as). One end of filter is composite, other metal; open at both ends. Dealer has the newer bowl in stock and for less than $5.00. Awaiting its arrival now. Seems the new fuel filter is longer, wider, metal at both ends, and closed botton. Hopefully the new bowl will screw right in. Don't know if they still have two O-Rings but guess they do. I didn't find either a spring nor the small O-Ring upon removal of bowl/pot.
