2210 carbon monoxcide posining with cab
   / 2210 carbon monoxcide posining with cab #61
Your right, O2 & N2 atomspheric gases are both polar covalent bonded molecules due to their outer shell electron orbital interactions.
They do become so much more entertaining when they become monovalent don't they? /forums/images/graemlins/wink.gif
   / 2210 carbon monoxcide posining with cab #62
</font><font color="blue" class="small">( </font><font color="blueclass=small">( your 100cc 4-stroke single cylinder spark ignition gasoline lawnmower engine as well as your 50cc 2-stroke single cylinder spark ignition weedwacker gasoline engine, but NOT your 2-3 liter 3-4 cylinder diesel engine in your tractor. )</font>
Like I said though.. There are 'all fuel' spark ignition engines that burn diesel, kero, and distalate / TVO.. I'd guess at that point they fall into the same problems as a gas / spark engine.. and not as 'safe' as a diesel engine using compression ignition.. correct?
Soundguy )</font>
Anything that has a molar ratio of more fuel to less air is going to result in a higher percentage of CO production, including everything you stated and allot more like gas hot water heaters, gas stoves, sterno stoves, charcoal grills, etc.
Carbon monoxide poisoning problems inside homes fro these items epidemiologically results in many many more deaths than any accidental or suicidal exposures on agricultural equipment does.
   / 2210 carbon monoxcide posining with cab #63
</font><font color="blue" class="small">( molar ratio )</font>
Last year our molar ratio was too high. They tunneled under the front yard and made a mess of the grass. I bought one of those spear traps but never seemed to spear any. I didn't think I could convince them to chew bubble gum to plug their insides. There have been many other methods suggested here in the past. My most successful approach was smashing down all the tunnels, come back in an hour and find one that was re-activated, watch for new movement, and quickly dig them up. They DO NOT like being in the sun.
I do, however, believe I understand why connnecting my diesel tractor's exhaust to the burrow was unsuccessful! /forums/images/graemlins/grin.gif
   / 2210 carbon monoxcide posining with cab #64
/forums/images/graemlins/grin.gif LOL, at least now you have black sooted molar ratios running around now all over the place.... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / 2210 carbon monoxcide posining with cab #65
</font><font color="blue" class="small">( ( molar ratio )
Last year our molar ratio was too high )</font>
I've got 13 cats on my farm. my molar ratio is so low that my test equipment isn't calibrated enough to read it.. I send it out to a lab to have it anylized! /forums/images/graemlins/shocked.gif /forums/images/graemlins/grin.gif
Soundguy
   / 2210 carbon monoxcide posining with cab #66
Have an endodontist take a close look at those teeth, can't do much chewin' without a good set of molars..... /forums/images/graemlins/wink.gif /forums/images/graemlins/grin.gif
   / 2210 carbon monoxcide posining with cab #67
</font><font color="blue" class="small">( about 0.03%, noble gases )</font>
Skypup,
You are showing your age. At work I am the only one who uses the term "noble gases" and they all tell me I am OLD.
Phil
   / 2210 carbon monoxcide posining with cab #68
</font><font color="blue" class="small">( Skypup,
)</font>
I feel old now too.. I use 'noble gasses'.. course.. I also use the term 'accumulator'.. and I'm not refering to an A/C system. ( registers.. )
Soundguy
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
2015 Freightliner M2 106 Terex BT2047 10-Ton Crane Truck (A51691)
2015 Freightliner...
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A52377)
2019 Generac...
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
PALLET OF 15-BLACK GROUND PROTECTION MATS. 4FT X 8FT (A53843)
PALLET OF 15-BLACK...
