2305 3ph control
/ 2305 3ph control #1
WV 2305
Recently purchased a 2305 and started using the 3 point hitch for my new rototiller. Question concerns control lever, seems that it takes more force to put it in the down position that I feel it should. When lifting and the automatic kickoff returns it to neutral it seems ok, but then when I want to lower the implement it has a hard detent feel to it also the same feeling when trying to partially raise the implement.
Is this normal? New dealer not much help over the phone.
Thanks in advance.
/ 2305 3ph control #2
On mine the detent effort is the same in both directions. I'd say there's something wrong. Have you checked to see if there is something bent or interfering with the travel of the lever?
/ 2305 3ph control #3
I've noticed on my 2305 the lever will rub on the seat if I'm sitting slanted towards that side. Otherwise, the detent feels the same in both directions.
2012 FORD F150 CREW CAB PICKUP TRUCK (A66091)
2012 FORD F150...
Unused 2023 Land Pride RCF2060 5ft. Rotary Brush Cutter Tractor Attachment (A66734)
Unused 2023 Land...
PALLET OF HYD HOSES (A68842)
PALLET OF HYD...
2014 Ford Escape SUV (A66738)
2014 Ford Escape...
Palfinger ILP 3300 3,300lb Truck-Under Lift Gate (A68183)
Palfinger ILP 3300...
Unused 2023 Kubota AP-SSG2024 24in. Hydraulic Stump Grinder Skid Steer Attachment (A66734)
Unused 2023 Kubota...
