2305 drive shaft fan repair/replacement
   / 2305 drive shaft fan repair/replacement #31
Two things. First is to put heavy grease on both splines before you install the drive shaft. Just like we use to do in the old days to save the spline. My input shaft spline into the rear end is pretty worn. Second is to put the snap ring on the front coupling just shy of the pin hole and once the pin is in it's easy to slide it the rest of the way into the groove. No hassle using the priers in that tight spot.
Blue Concrete Test Shed (A52377)
Blue Concrete Test...
Bad Boy Pro Z Zero Turn Mower (A53117)
Bad Boy Pro Z Zero...
2013 Ford F-650 Flatbed Truck (A51691)
2013 Ford F-650...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2011 Kubota R520S 4WD Articulated Wheel Loader (A51691)
2011 Kubota R520S...
