Dutch445
Elite Member
The 2520 does have a longer frame, to accomodate
a 72" mid mower, but that won't really help
in your application. The 2320 and 2520 use the
same backhoe, which is a great little hoe!
I don't see much that a 2520 will do that
the 2320 won't do for what you want to do.
If you need more machine, then you probably should
step up to the 3020, but that could be overkill
for your needs.
As far as 2320 vs 2305, yes,, large differences.
not only clearance, tire size, backhoe performance,
but also dual brakes, folding rops, separate seat for
the backhoe, (that twisting one on the 2305 is very
clumsy) and more hydraulic power where it counts.
don't skimp on the loaders, that 200CX is worth it in
the long run, even if you don't intend to remove it
at this point.
for your needs.
at this point.
