Backhoe 2305/ Woods BH6000 Backhoe Update
   / 2305/ Woods BH6000 Backhoe Update #31
I have a 2210 with the woods hoe. The pressure and flow are good. Most movements are best operated one at a time, but the speed is good for the size of hoe. The controls are somewhat easy to learn and with practice you'll have it down quickly. Second time at the controls, I dug two ditches for drain pipe, each ditch was about 10' long, 30" deep, 12" wide. It took about 45 minutes to dig both. Certainly a time and lower back saver over a shovel. I have about 10 projects planned for the hoe (more with neighbors/friends requests).
I'm glad to hear that. I noticed movement seems good using 1 control at a time. What RPM do you run at? It seems to move quickly even just above idle.
   / 2305/ Woods BH6000 Backhoe Update #33
Usually 2500. As needed I'll feather the controls to reduce the boom or swing speed.
What are the part number(s) to the seat swivel bracket(s)? I may install that part on my 2210. Currently I have two seats, one for the tractor and one for the hoe.
Seat Assembly Listed Only as Pieces.....#'s are
1# 1009649 Retainer Ring
1# 1008307 Seat Lift Link
1# 1008374 External Retaining Ring, .375
1# 1016552 Tractor Seat Bracket
1# 1016555 Seat Mount Plate
1# 1016561 Lift Bracket
2# 5/16 NC x 3/4 HHCS GR5
2# 5/16 Lock Washer
2# 5/16 Flat Washer
1# 3/8 NC x 1-1/2 HHCS GR5
1# 3/8 NC Locknut
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
CATALOG UPDATES (A53084)
CATALOG UPDATES...
2014 FORD Transit Connect CARGO VAN (A50323)
2014 FORD Transit...
2024 JOHN DEERE 6110M LOT NUMBER 56 (A53084)
2024 JOHN DEERE...
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
100 GAL FUEL TANK W/PUMP (A52472)
100 GAL FUEL TANK...
