2310d 4wd problem
   / 2310d 4wd problem
I'll take the driveshaft off, drain the fluid and look at the drop box again......
   / 2310d 4wd problem
Thanks for the help Winston. Be back after while.
   / 2310d 4wd problem #13
Don't know that I am helping any. Might take some pictures of your findings.
After gazing at the 2210 parts list and then your picture it sure looks like the sliding gear is turned around backwards on the shaft. Probabaly don't know what I'm talking about but sure looks that way.
   / 2310d 4wd problem
It is the way it always has been, used to work fine.
I took it all apart and it sure looks right. Drop box engages 4 wd gear when lever is pushed back and forth just fine. Same thing though when put back together. 4wd works, or seems to. 2wd will not spin tires when trying to drive. This time the tires did spin sometimes when in reverse.
   / 2310d 4wd problem #15
got me baffled. I am wondering what would happen if you disconnected the front drive shaft. surely the front wheels wouldn't slide then. If so, the problem would be up there. Doesn't seem likely if you were able to spin the wheels when jacked up. Just another thing to try. Just rattling, sorry I haven't been able to help.
this might be of interest to you. http://www.ebay.com/itm/Yanmar-Trac...=BI_Heavy_Equipment_Parts&hash=item2a3a73905d
   / 2310d 4wd problem
Last test for night....did a bit of slow driving in shed.
In 4wd, forward and reverse, all seems to be working fine. I don't actually know it it is working, but the tires roll just fine.
In 2wd, reverse seems to work fine, but when put in forward gear the left tire seems to turn fine but the left tire is trying to spin backwards and just kind of skids along on the concrete.
   / 2310d 4wd problem #17
Maybe that's why the part was bent. Something went wrong (somewhere) and the part bent.
   / 2310d 4wd problem #18
I know it is a lot of work but removing the drive shaft and doing your driving test should prove whether the problem is in the drop box or front axle. If it rolls free forward and backwards with the drive shaft removed the problem would have to be in the drop box area.
   / 2310d 4wd problem
Had a tooth cut out yesterday so I have not had time to mess with it. Might have more time tomorrow. Will report back once I have taken it off and tested. That is the only thing that I can think of left to do.
   / 2310d 4wd problem
Ok, I took the 4wd drive shaft off today and drove the tractor around in the shed a bit. Front wheels turn just fine in 2wd so the problem is either in the drive shaft or drop box....I think.
While the shaft was off I checked on a couple of things. Where the shaft connects at the front is still turning in both 2wd and 4wd. At the back, coming off the drop box, it does not turn in 2wd but does in 4wd. I think that is all normal but dont know. I talked to Aaron at. Hoye today and he said the shaft would still turn even when in 2 wd. So with this in mind.......thoughts?
1601 (A58375)
1601 (A58375)
2279 (A58376)
2279 (A58376)
Unused Kivel 48" Pallet Fork Attachment (A55272)
Unused Kivel 48"...
Ford 8510 (A53317)
Ford 8510 (A53317)
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
2017 Ford F-350 Utility Flatbed Truck (A56858)
2017 Ford F-350...
