2538 how many grease zerks ?
   / 2538 how many grease zerks ? #11
If you use a flexible hose on the gun, you have to anyway. I used to use a rigid tube end on my gun but found the flexible hose style to work better, especially when using the air powered gun. One hand on the trigger and the other attaching/detaching the L&L.
   / 2538 how many grease zerks ? #12
That's what I figured.
   / 2538 how many grease zerks ? #13
I took it that the lock n lube was a one handed affair. One hand on the gun, the other on the tip. Does it hold for clogged zerks?
I use it on a rigid tube. Still need to release one hand to open the "latch" to attach and then again to release it. Still very much worth it. Only takes a second. Most clogged zerks clear without special effort. I still occasionally have to remove zerks for cleaning or replacement.
   / 2538 how many grease zerks ? #14
So it looks like a L&L with the power gun would be a killer combination.
   / 2538 how many grease zerks ? #15
I have a power gun but frankly I prefer my lever action Lincoln with rigid tube and lock'n lube. The power gun is a bit heavy for one hand and you need to deal with the snake using the other hand. Power lube only takes a couple seconds per zerk so you are essentially using it with one hand.
   / 2538 how many grease zerks ? #17
2538 Tractor
I counted 7 Grease Zerks
One on each front axle, one in front and behind the steering pinion, two at the forward reverse pedals and one on the brake pedal.
If someone finds more please let me know
2538L Loader
I only counted 12 - six on each side
Enjoy!
   / 2538 how many grease zerks ? #18
2538 Tractor
2538L Loader
Enjoy!
Aren't there any on the 3PT (I've never greased a Mahindra but my Kioti has all the ones you mentioned plus the 3PT).
   / 2538 how many grease zerks ? #19
Hmmm - didn't check, manual doesn't show them but it's pretty much useless, i'll have to check.
   / 2538 how many grease zerks ? #20
If the Mahindra is set up like the Kioti, then the 3PT arms are attached to a linking rod (not sure what it is really called) so they move together. That "rod" has some bearing surfaces and at least on my tractor has a zerk to lubricate it.
Takeuchi TB260 (A50120)
Takeuchi TB260...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2002 John Deere 5220 (A50120)
2002 John Deere...
2025 78in Rock Bucket Skid Steer Attachment (A50322)
2025 78in Rock...
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A50323)
2008 Ford F-250...
