mike35549
Not counting the FEL the book only shows 5 zerks is that all there is I was expecting 2-3 times that many.
Well if you want more zerks get a backhoe then think about buying a power grease gun for yourself like I did. Between the FEL and backhoe you'll be busy. Oh yeah have lots of grease on hand too.
I use the lock n lube. Great product.
I like mine too. Doesn't interfere with getting the tip on either though it does require that you move your hand off the gun.
If you use a flexible hose on the gun, you have to anyway. I used to use a rigid tube end on my gun but found the flexible hose style to work better, especially when using the air powered gun. One hand on the trigger and the other attaching/detaching the L&L.
I use it on a rigid tube. Still need to release one hand to open the "latch" to attach and then again to release it. Still very much worth it. Only takes a second. Most clogged zerks clear without special effort. I still occasionally have to remove zerks for cleaning or replacement.I took it that the lock n lube was a one handed affair. One hand on the gun, the other on the tip. Does it hold for clogged zerks?
I have a power gun but frankly I prefer my lever action Lincoln with rigid tube and lock'n lube. The power gun is a bit heavy for one hand and you need to deal with the snake using the other hand. Power lube only takes a couple seconds per zerk so you are essentially using it with one hand.So it looks like a L&L with the power gun would be a killer combination.
2538 Tractor
I counted 7 Grease Zerks
One on each front axle, one in front and behind the steering pinion, two at the forward reverse pedals and one on the brake pedal.
If someone finds more please let me know
2538L Loader
I only counted 12 - six on each side
Enjoy!
Hmmm - didn't check, manual doesn't show them but it's pretty much useless, i'll have to check.Aren't there any on the 3PT (I've never greased a Mahindra but my Kioti has all the ones you mentioned plus the 3PT).
Thanks
