2n hard starting when engine is cold.
/ 2n hard starting when engine is cold. #1
tbf8170
Holly, Michigan
Ford 2n
Any ideas for what to look for on a Ford 2n that is hard starting when engine is cold? 12 volt system and carb was replaced within last 3 years before I bought it. Plugs get wet with gas, but each plug shows good spark when cranking.
/ 2n hard starting when engine is cold. #2
Are you getting a good blue spark? If the 12V conversion was done correctly it will have a 12V coil (they sell them for the 2-8-9N's) or a resistor for the 6V coil.
How about a compression check? Those are low compression engines and when it's weak they are hard to start cold.
Might just go to a puff of either to start it cold.
/ 2n hard starting when engine is cold. #4
if it has good spark, and you can make wet plugs ( good fuel flow ).. then i would for sure check compression next.
post back
2007 International 4300 S/A Dump Truck (A64556)
2007 International...
3 Point Hay Forks (A62613)
3 Point Hay Forks...
1994 Geo Tracker, 5spd, Soft Top (A62679)
1994 Geo Tracker...
Metal Sasquatch Holding Beverage (A65583)
Metal Sasquatch...
5' Bush Hog Mowing Deck (A62613)
5' Bush Hog Mowing...
2022 EZ-GO ELITE...
