3 bottom plow purchase advice
   / 3 bottom plow purchase advice
more questions...
On a semi mount does the plow get raised by both the 3 point system and the tire assembly? Does the tire assembly factor into the adjustments for proper plow tilling?
   / 3 bottom plow purchase advice #12
With mine I had to raise the 3pt arms and then hit the hydraulics to raise the rear wheel. It took a little learning to get use to it to use but once you get use to it, it became second nature.
   / 3 bottom plow purchase advice #13
1st they still do make and sell 3 btm fully mounted plows. I know people with them less than 10-15 years old.
With a semi mount plow you are using only the 2 lift arms to pick the front of the plow. The rear wheel also is used for not only lift but steering and setting your rear depth. I like semi mounts and still plow about 30 acers a year on my friends farm farm with one. Many semi mounts can adjust the width of plow, change the amount of roll, and have a side hill hitch which allows them to change with conditions. The smallest semi mounts I've ever seen is a 4 btm. With your tractor I would stay with the 3 btm, 4 may be too much to pull.
Another option is to look for a roll over plow, I see them in a 3 btm. These plows have 6 btms, 3 on each side of the beam. The one set is right handed plows, the other is left. So you can start on one edge of a field and just keep working across plowing back and forth.
Fastline.com, Machineryfinder.com, craigslist and few others are good places to look for a plow.
Here are some pictures of roll over plows.
http://www.charlestowncooperativefarm.org/sustainablepractices.html
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=jd&th=250265
http://www.nmmachinery.com/manufacturers/kuhn/plows/
   / 3 bottom plow purchase advice #14
Sorry, forgot to add semi mount plows usually have a depth wheel on the back so all you do is drop the rear of the plow and it automatically goes to the proper depth.
   / 3 bottom plow purchase advice #15
With a semi mount plow you are using only the 2 lift arms to pick the front of the plow. the rear wheel also is used for not only lift but steering. I like semi mounts and still plow about 30 acers a year on my friends farm farm with one. The smallest semi mounts I've ever seen is a 4 btm.
Another option is to look for a roll over plow, I them in a 3 btm. These plows have 6 btms, 3 on each side of the beam. so you can start on one edge of a field and just keep working across plowing back and forth.
Its my understanding the rollover plows are harder to pull. If you can pull a standard 3-14 plow then you would only be able to handle a 2-14 rollover. I've never used one,just going by what was said to me. The idea behind it though is its still faster because your not wasting a lot of time driving headlands.
So with the plow in the ground is the wheel at the end of the plow doing anything but just hanging above the ground?
   / 3 bottom plow purchase advice #17
It helps with steering still. It never floats in the air. If I recall its just gravity down. Haven't paid attention to mine in a few years but only recall one hydraulic line running back to there.
lots of good information thanks to all.
Jason25
   / 3 bottom plow purchase advice #19
I don't know why they would pull harder. I could see having to down size though based on weight, having double everything has to be heavy.
   / 3 bottom plow purchase advice #20
Here is a picture of a semi mount 3 btm plow. It has a single wheel in the back so it would set depth and steer. The linkage above the beam goes from the front hitch to the rear wheel. Now many do have a 2nd depth wheel, where one wheel rides in the furrow and the 2nd on the ground. Some the tail wheel in only in the furrow, and some are "on-land".
IH model 710 plow for sale
Here ia an old thread with a pic of a IH plow with both wheels.
http://www.tractorbynet.com/forums/ag-tractors-machinery/116685-ih-720-plow.html
Add with pic of single rear wheel and different steer linkage.
JD 5 bottom semi mount plow
Rollover plow with on land rear depth wheel.
Light mounted reversible plough | RC31
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
JOHN DEERE 560M (A53084)
JOHN DEERE 560M...
Skid steer auger plate (A50322)
Skid steer auger...
49" X 74" EXPANDED METAL RAMP GATE (A54756)
49" X 74" EXPANDED...
2007 PETERBILT 335 FUEL & LUBE TRUCK (A51406)
2007 PETERBILT 335...
UNUSED SDLANCH SDLGC ELECTRIC GOLFCART (A54756)
UNUSED SDLANCH...
