3 point hitch broke
   / 3 point hitch broke
I had assumed the warranty was for 2years. After reading your post, I checked the book. It might be covered. (Fingers crossed).
Thank you for giving my brain a jog!
   / 3 point hitch broke #14
That's really a shame. Good luck on the repairs and hope it's still covered.
   / 3 point hitch broke #15
Ditto! And kudos on taking it down as far as you did. I hope the dealer views that as saved labor, and doesn't give you some hard time about it. Make sure to tell them you've documented the teardown process, with hi-res pics (sounds good, anyway, right?).
Best of luck!
My Hoe
   / 3 point hitch broke #16
That's really too bad. Hope the dealer takes care of you and gets you back in the seat soon.
   / 3 point hitch broke #17
Wow! That's terrible. Good luck getting that fixed at a decent price.
   / 3 point hitch broke #18
Seriously, what a bummer! Pls keep us updated on repairs and cost.
What was the size/weight of your box blade?
48" rollover box blade. 525 lbs.
Update
They came & picked up the tractor Friday. Went down to see what else might have happened. Thankfully the only other damage I had already found. The splines in the left hand lift arm were partially stripped. All the parts are supposedly in the Texas warehouse. The 3 years on the warranty had expired on June 26. The problem occurred on July 5. Kubota is going to help with parts cost. How much I don't know yet. Here are some more pics.
2004 Sterling Acterra Cab and Chassis S/A Truck (A55852)
2004 Sterling...
ASCO Transfer Switch (A52377)
ASCO Transfer...
2011 DOOSAN G25KW GENERATOR (A53843)
2011 DOOSAN G25KW...
2008 Chevrolet C7500 Truck, VIN # 1GBM7C1G78F413329 (A54865)
2008 Chevrolet...
UNUSED AGT SDA 140W WHEEL LOADER (A52706)
UNUSED AGT SDA...
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
