3-Point Hitch Problems
   / 3-Point Hitch Problems #31
Thanks for the help everyone!!! :thumbsup: I was able to get the nuts loose and get everything tight and level. Now I have one last question: to get the implement off, I just turn the main nut the opposite way and leave the stop nut in the same spot, right? Oh, and here are the pics:
You have the right idea for removal of the carryall.
It is a PIA to keep turning that turnbuckle each time you put on an implement, however.
Larger tractors have the turnbuckle (or chains) on the outside of the arms so it is simply a matter of swinging the arm wide and then swinging them back to mount to the pins - no adjustments necessary. That is why teg mentioned earlier to turn the lift pins on the carryall to the inside. Then your lift arms would swing out to engage the lift pins.
However, a trick I used was to remove one of the pins from the clevis on the end of the turnbuckle. That frees up the arm to swing out and then back to connect. Then put the pin back in and no adjustments have to be made. A "hairpin" clip on the clevis makes it much easier.
Finally, I ended up getting a Pat's Easy Hitch and all of this nonsense was over. Just back up, lift the arms to engage the pins, hook up the top link and away you go.
   / 3-Point Hitch Problems #32
JDGreenGrass, I was just thinking...What do you think of just putting a piece of plywood on the back of the carryall (just the width of the frame)...Do you think that will help with hooking it up???
Yes, that would work in most cases. Just remember that there may come a time that you wished you had a wider "wall." For instance, you may fit more firewood on the carry-all if you use a full length of wood.
But, as others are suggesting, a quick hitch may be the best option. I don't have a quick hitch and frankly I don't feel the need for one. I don't change attachments all that often.
And, to back up a bit, I think pressure treated decking would be ideal for material to finish off the carry-all. 1x6 or 1x8.
   / 3-Point Hitch Problems #33
Like I said before, my carry-all is a bugger to hook up. Part of the reason is that once you install your planking of wood it leaves no space for the 3pt. arms to go back beyond the pins. I know, it's hard to explain.....
My carryall box is made from 2X lumber and that hookup problem was obvious from the get-go. A small spacer between the upright arms and the box lumber would have solved the problem, but, since I didn't want to have to redrill all the holes, I just chiseled/sanded out a bit of cavity in the offending boards to give the ends of the lift arms some clearance for hookup.
As for replacing cotter pins with linch pins or hairpins...I use both types for convenience, but you need to check them often. More than once, I have lost a pin (both kinds) in brush. This included losing the pin that held one of the lift arms onto the tractor while mowing brush... with bad results (the lift arms are now bolted on!).
BOB
   / 3-Point Hitch Problems #34
This is what I did. I hate the turnbuckles. I'm making the adjustable side links now.
Interesting. you cut the whole thing in half and added sliding bars. how is that working out for you?
   / 3-Point Hitch Problems #35
radioman,
It works real good!!!!! They were kind of hard to make, or I should say harder then the others I made. You can't see it in the picture, but the ends have to swivel just a little. I'm working on a better way to do that right now. Also the plate was kind of hard to cut, I don't have a band saw.
All of the above is the exact reason I went with a quick hitch. Even if I have to adapt some of the "non i-Match compatible" implements, once that is done, I never have to screw around with this stuff any more.
Something to think about.
Since all we have now is the carryall, I think we will wait on the quick hitch.
It is actually not to hard to turn the turnbuckles.
BOB
I was able to get the carryall hooked up. It was a pain, but was not too bad...
Brent 1082 Auger Wagon (A59814)
Brent 1082 Auger...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
3ft Metal 5-Point Star (A59231)
3ft Metal 5-Point...
2013 Ford F-250 4x4 Ext. Cab Pickup Truck (A60460)
2013 Ford F-250...
2014 Nissan Altima Sedan (A59231)
2014 Nissan Altima...
2003 UTILITY TRAILER MANUFACTURER UTILITY TRAILER MANUFACTURER (A55745)
2003 UTILITY...
