3 point lowering speed knob question
   / 3 point lowering speed knob question #2
DOn't know what to tell you. Mine wouldn't budge either when I first got the tractor (it was used). Since everything was working fine and I didn't feel like putting some pliers on it. Then weekend before last I was mowing and noticed it was loose. WTH?? Almost felt like it was going to unscrew and come out or something so I gave it a few turns...not thinking. I was running the FM and needed to lift it over some junk and it stuck up. Long story short I had twisted the knob an hour earlier and forgot. After a couple jumps on the FM and linkage checking, I remembered the knob. I'm gonna leave it alone from now on!!
It should move though.
Good Luck,
Rob
   / 3 point lowering speed knob question #3
Mine was stuck so solid when I got my L3400 that I wasn't sure it was supposed to move.
After determining that it was, I soaked the shaft with WD-40 for about 24 hours. Of course, it still didn't budge but after puting alternating CCW and CC pressure with hand power for 15 or 20 tries and more WD-40, I sensed that it budged, probably 1/128th of an inch. Back and forth 30 more times and more WD-40, now I can turn it with my pinky.
Persistence may be a good alternative to force for this one. LOL
It worked fine when i got the used BX1500 in november but it's stuck now.
   / 3 point lowering speed knob question #5
Try the one on the new BX1500 or the BX23. LOL
Sorry Lee, couldn't help myself.
Now you got me worried, I haven't played, er I mean tested mine yet. I'll let you know tomorrow.
   / 3 point lowering speed knob question #6
it may seem obvious, but it really is hard to move when the weight of the mower deck is on it. make sure you raise the 3-pt hitch and deck if attached up so it frees up the linkage on the knob. if that doesn't do it, take a look under the machine and make sure there aren't any sticks or other gunk jammed in the threads or the little stepped cog that the mounting arms settle into.
amp
   / 3 point lowering speed knob question #7
Ditto "ampsucker's" post. I have found on my bx1500 that the knob is very hard to turn with the mower lowered. But raise it up and turns rather easily.
   / 3 point lowering speed knob question #10
I think you're confusing the mower deck height adjust (left side of machine) with the lowering speed control (right side of the machine).
John Deere Gator (A53317)
John Deere Gator...
2004 Pierce Tilt Crew Cab Enforcer Fire Truck (A55853)
2004 Pierce Tilt...
Mini John Deere Truck (A55853)
Mini John Deere...
skeleton / rock bucket (A56857)
skeleton / rock...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2017 Mercedes Benz GLA SUV (A56859)
2017 Mercedes Benz...
