3 point stabilizer adjustment
   / 3 point stabilizer adjustment
one more pic
one more pic
   / 3 point stabilizer adjustment #13
The points are way out of line and you need some type of turnbuckle also. Hopefully there mounting holes so that you can add brackets. A lot of these smaller tractors locate the sway links to the inside of the lift arms. Look around the drawbar area to see if there is any attachment points there.
   / 3 point stabilizer adjustment #14
thanks ... you mean towards the PTO location?
   / 3 point stabilizer adjustment #17
I didn't have much luck tryin' to hold the arms from outside. I moved my chains to the lower bolts of the pto cover. I only adjust them tight enough to keep an implement from hitting the tire at ground engagement height. When the hitch is raised the chains, because they are fixed at the bottom, pull increasingly on the lift arms. There's just a tiny bit of slack at full lift. /forums/images/graemlins/wink.gif
   / 3 point stabilizer adjustment #18
   / 3 point stabilizer adjustment #19
<font color="blue"> you mean towards the PTO location? </font>
Yes, below the PTO shaft.
   / 3 point stabilizer adjustment #20
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
CHANDLER 20FT 16 TON HYDRAULIC SPREADER (A52472)
CHANDLER 20FT 16...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2022 CATERPILLAR 259D3 SKID STEER (A51246)
2022 CATERPILLAR...
CATERPILLAR IT28G (A52472)
CATERPILLAR IT28G...
