3 point stabilizer adjustment
   / 3 point stabilizer adjustment
one more pic
one more pic
   / 3 point stabilizer adjustment #13
The points are way out of line and you need some type of turnbuckle also. Hopefully there mounting holes so that you can add brackets. A lot of these smaller tractors locate the sway links to the inside of the lift arms. Look around the drawbar area to see if there is any attachment points there.
   / 3 point stabilizer adjustment #14
thanks ... you mean towards the PTO location?
   / 3 point stabilizer adjustment #17
I didn't have much luck tryin' to hold the arms from outside. I moved my chains to the lower bolts of the pto cover. I only adjust them tight enough to keep an implement from hitting the tire at ground engagement height. When the hitch is raised the chains, because they are fixed at the bottom, pull increasingly on the lift arms. There's just a tiny bit of slack at full lift. /forums/images/graemlins/wink.gif
   / 3 point stabilizer adjustment #18
   / 3 point stabilizer adjustment #19
<font color="blue"> you mean towards the PTO location? </font>
Yes, below the PTO shaft.
   / 3 point stabilizer adjustment #20
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
91013 (A48082)
91013 (A48082)
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
JLG MAN LIFT (A52472)
2014 FORD F-350 SUPER DUTY (A52472)
2014 FORD F-350...
Towable Orchard Sprayer (A51691)
Towable Orchard...
