3 Pt. Backhoe
   / 3 Pt. Backhoe #11
Well, I decided to play it safe. Bought a slightly used NH subframe for $250. I should be able to figure out a way to mount the Liberty backhoe with it.
I think you got very lucky to find a used sub frame for your TC 30. I think you've made a good decision to mount the BH to it. Should be easy to do.
   / 3 Pt. Backhoe #12
I can take pictures of my B.H. , with it off the tractor to give you ideas on how to modify your B.H. to work with your sub-frame . A Welder , some Steel Channel and some Steel Tube should make a decent frame to attach to the sub-frame .
Fred H.
   / 3 Pt. Backhoe
Fred, I would appreciate that. What thickness of steel would you use?
   / 3 Pt. Backhoe #14
Exactly What Did You Buy when you say " Sub - Frame " ? Going out to Shoot some pictures now of B.H. On and Then Off , But Not sure What parts you Have already ??
Fred H.
   / 3 Pt. Backhoe
Found a used subframe from a new Holland dealer in Missouri called Boaktings. He told me they took a T C 30 on trade and the new buyer for some reason did not want the sub frame. Told me it runs front to back of tractor. I talked to Liberty and they said the sub frame wasn't necessary but also wouldn't hurt. He said it should be no problem mounting this to a sub frame. I don't have anything yet. The sub frame has been shipped but not the hoe.
   / 3 Pt. Backhoe #16
Here are Pictures of 757 Attached and Unattached , of actual sub-frame attachment points to B.H. , Sub frame and Both the Front and Rear sub frame mounts on Tractor itself that stay on tractor even if B.H. is removed .
Fred H.
   / 3 Pt. Backhoe #17
So based upon your last msg. , If You are getting the sub frame ( Not sure if they are also giving the front and rear mounts ) , It really would be no big deal I am thinking to attach the B.H. to the sub frame . Actually attach sub frame to tractor first , all of it , then back tractor up to unattached B.H. and start taking measurements and getting ideas on how to stick the two together . :)
Fred H.
   / 3 Pt. Backhoe
Fred, Thank you for your time and advice. From your pictures this backhoe may not be too big of a project. I will let you know when I get it all hooked up. Thank You again.
   / 3 Pt. Backhoe
Fred, the subframe came yesterday and I put it on today. Had to make 2 50 mile round trips to get the proper size and grade bolts but it all worked out. Your pictures were a great help for me today, Thank You again!
John Deere 460M (A57148)
John Deere 460M...
2010 Volvo XC90 SUV (A56859)
2010 Volvo XC90...
1837 (A58374)
1837 (A58374)
LOT OF SHOVELS (A52708)
LOT OF SHOVELS...
Golf Cart (A55787)
Golf Cart (A55787)
2023 PJ Trailer 1D192 14ft. 5 Ton T/A Dump Trailer (A55973)
2023 PJ Trailer...
