Gordon Gould
Super Member
- Joined
- Apr 1, 2007
- Messages
- 6,711
- Location
- NorthEastern, VT
- Tractor
- Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
If it was mine and I hadn't found something definitive or wrong yet I think I would remove two loader hoses at the block and plug the block ports with male plugs. I would remove the pump output hose which goes to the IN port of the FEL valve and I would remove block inlet hose which should come from the POWER BEYOND port of FEL valve. You can leave the tank hose connected. Then turn the block valve to the NO LOADER position. Start the tractor and try the 3ph. If the problem is gone the trouble is in the loader valve or loader plumbing as mentioned by jimmer. If you still have the problem it is in the 3ph.
If you try this make sure to relieve all pressure before any disconnects are made and have no weight or impliment on the 3ph with the bucket flat on the ground.
You should find these connection locations in your book.
