3020 JD- 241 cid engine help
/ 3020 JD- 241 cid engine help #1
KWRFarms
Springdale, AR
JohnDeere/3020,4010
Does anybody have some good info on finding engine rebuild parts for the four cylinder 241cid engine the the late production run of the 3020 John Deere tractors. It seems to be an odd-ball engine, having been run only two years and only in the 3020---to the best of my knowledge. Thanks for any help.
/ 3020 JD- 241 cid engine help #3
Welcome to TBN :)
I moved your thread to the John Deere Vintage Tractors Forum.
/ 3020 JD- 241 cid engine help #4
Are you familar with this magazine? Green Magazine, the monthly magazine for John Deere enthusiasts There's a whole slew of advertisers that offer new, used, refurb parts for older, JD machines. Gotta be somebody in there that supplies parts for that engine.
AKfish
/ 3020 JD- 241 cid engine help #5
Back when I sold 3020's new I don't remember any 3020's that had different CID engines for only 2 years. Granted later 3020's were advertised at 70 pto HP instead of 65 pto HP as the first ones. Late model 3020's were built from '69-'72' Tratordata lists 227 CID for gasoline/LPG & 270 CID for diesel. The earlier 4 cyl. engines could have later model cylinder liners/pistons installed to increase the CID. The same basic Waterloo built 4 cyl engine was used from '61-'72. Which fuel does your engine burn?
Update. I just viewed the JD parts catalog #1115 and it shows a 4" bore(fits block #R26150) & 4.25" bore liners fits all the later blocks.
/ 3020 JD- 241 cid engine help #6
I think TractorData.com - information on all makes and models of tractors lists that engine as a gas model. Was offered in the later/last year's of production.
AKfish
/ 3020 JD- 241 cid engine help #7
I got this info. from Tractordata's website
Type: Diesel synchro range 2WD
PTO power (rated engine speed): 71.26 hp [53.1 kW]
PTO fuel use (engine speed): 5.1 gal/hour [19.3 l/hour]
PTO power (rated PTO speed): 64.32 hp [48.0 kW]
PTO fuel use (PTO speed): 4.4 gal/hour [16.7 l/hour]
Drawbar power (max): 61.47 hp [45.8 kW]
Drawbar fuel use (max): 4.9 gal/hour [18.5 l/hour]
I also discovered 241 CID engine is a gasoline/LPG
2000 Hino (A64194)
2000 Hino (A64194)
2013 International DuraStar 4300 General Cable T40-C 35ft. Bucket Truck (A64194)
2013 International...
2014 KENWORTH T370 ROAD TRACTOR (A64280)
2014 KENWORTH T370...
7071CFL (A64553)
7071CFL (A64553)
2006 CHEVROLET EXPRESS 4X2 SERVICE BOX TRUCK (A67147)
2006 CHEVROLET...
2020 INTERNATIONAL LT625 SLEEPER (A59910)
2020 INTERNATIONAL...
