32" Doug Fir stump - Do I have a chance of success?
   / 32" Doug Fir stump - Do I have a chance of success? #31
Congratulations :) After you get it out you see there wasn't much holding it, it's amazing what those tiny little roots hold!
Was that a rental machine? I can't believe it was able to lift that monster!
JB.
snip...
JB.
No rental. It was purchased last fall. Took about 8 hours of seat time.
I'm real glad I went with the 110 instead of the 46BH for my 2520!
   / 32" Doug Fir stump - Do I have a chance of success? #35
Good job.
Is that a Deere thumb on the hoe?
How do you like it? When I bought my thumb, the rumors going around were that the Deere thumbs were soft and not as durable as some others.
I got an Addington thumb, and while it has worked out well so far, I am somewhat disappointed in that there is a pin, maybe 2" in diameter which must be replaced with a longer one to give a pivot point for the thumb. The Deere thumb which came out was harder than a banker's heart. The one Addington supplied was the right diameter, but was a much softer steel, and did not have the same quality of finish.
Good job.
Yes, that is a Deere Thumb. I have not done any hardness testing. It seems to function just fine. But then, I really only had today to have a use for it so far.
And the seat time was actually less for the stump. Part of that time, I had to carefully dig the phone line and re-route it out of the way.
   / 32" Doug Fir stump - Do I have a chance of success? #37
Congrat's on the victory. A word of caution,try to load the loader arms abit more evenly. I had a similar job with a trio of white oaks and common stump. You want to see a massive taproot. I lifted the rootball with my forks and the weight was mostly on one loader arm. As I tried to load it into my dump trailer the uneven load almost tipped me sideways. Luckily I felt it an was very low to the ground. Now I use my grapple so I can just grab the load where I need to not where the forks fit.
Matt:D
2001 STERLING DUMP TRUCK (A54756)
2001 STERLING DUMP...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A53843)
2012 NORAM POWER...
96" X 53' FLATBED TRAILER (A52706)
96" X 53' FLATBED...
