3225 Hydraulics Problem
   / 3225 Hydraulics Problem #1
2010 John Deere 2520
I have a Cub Cadet model 3225 that has about 425 hours on it. I bought it new about 8 years ago and have been quite pleased with it.
Today, I was using it with my snowblower attachment and lost hydraulic power. First the hydro lift failed to actuate, and then soon I lost
power steering and then forward/reverse ability. I checked the transmission fluid level and found it low, but adding to fill (~4 oz) did not restore
operation.
As I was thinking about this, I found a broken spring right under the tractor - it's measures about 3/8" x 1 1/2" and is the color of brass. Looking in the parts manual, I can't find a sring that seems to be part of the transmission or hydraulic systems that matches this part. I can't believe the spring is not related to the problem, but I can't see where it might have come from. Can somone help?
Well, I figured out where the broken spring came from - it was between the front control rod shaft and the cam clutch (PN 732-3118 and rf no. 34 in the parts diagram). So now I think its failure may be unrelated to the hydraulic problem, but occurred when I pushed the forward and reverse pedals to test the hydrostatic drive. I'll get a replacement and then go through the air-bleed procedure I saw in another post on this forum. This was by cycling the F an R pedals with the tractor started and the free wheel mode lever pulled out.
   / 3225 Hydraulics Problem #3
Sorry to hear about your tractor's issue...
I'm no expert, but I am interested. I've got a first cousin to your machine in my garage! I won't promise that these observations will help at all, but here goes...
If I read your account correctly, it's interesting that you lost lift, steering and transport in that order. I wondered, but don't know, if this is also the order of pressure requirements for the hydraulic system components
Your account also implies to me that this failure that took at least several minutes to manifest itself.
Could you verify both of these?
Is there a chance that this is something simple like a clogged filter? If the filter was clogged, then you might first loose high pressure. As the pressure builds up across the filter, you might loose more and more pressure. If it was really cold, that could make it worse.
Again no great experience here, but trying to help with an idea or two...
Let us know how it goes...
Steve MacLeod
near Rochester, NY
Thanks for the reply - I'll respond after an update.
I was able to borrow the same spring part no. from the nearby cruise control linkage to restore the F/R linkage and cam clutch action. Then I disengaged the transmission, started her up, and cycled the F and R pedals for a couple of minutes. Stopped her, and saw no bubbles on the dipstick. Started up, with the transmission engaged and found no improvement in any hydraulic function. So I still need some help on this.
The lift was noticed first, as the blower was dragging as I backed up from making a pass. I then stopped it to check, added fluid, and when I restarted noticed I had no drive or power steering.
I could have a clogged filter, but there was no recent action that would cause it, like a filter or fluid change. On the advice of my dealer's service department, I have not changed the transmission fluid or filter - they said there was more risk of adding dirt than benefit to be gained, despite the fact that the owner's manual calls for a new filter at 100 hours and every 50 thereafter. It was not that cold when this happened - just about 35 degrees.
   / 3225 Hydraulics Problem #5
I'm hopeful that someone else will chime in, but, in the meantime, were/are there any odd noises or an unusual lack of noise? I know that hydro problems involving fluid sometimes result in odd noises. How about when you try to actuate the lift? Usually there is a whine associated with that. Do you have anything?
   / 3225 Hydraulics Problem #6
I'm afraid I disagree with the dealer. After 425 hours I would DEFINITELY change the filter. Are you using the synthetic drive fluid ($30+ per gal)? If you jack up the front of the tractor as high as possible and have the new filter ready to install you can do it without losing more than a pint of fluid. The filter is the simplest and cheapest option so I would definitely try that first. Make sure to use the correct filter.
Bob B.
Thanks for the replies, guys.
I really hear no noises when trying to use any of the hydro functions - it sounds like there's no fluid being pumped.
So I will try the filter replace option tomorrow - I have the correct part and synthetic fluid on hand. I'll post the results afterward.
   / 3225 Hydraulics Problem #8
You might try part 60 in the attached picture. (assuming kit 759-3926 is installed) If you noticed there is no key (part 25) in the kit. The pump adapter is held on with friction and lock-tite. If it loosens up, the hydro input shaft does not turn and no hydro action at all. If you don't have the 759-3926 kit and have parts 25 and 28 installed, the shaft must be turning, so, you are looking at more serious problems.
Definitely try the filter and add proper compatible fluid. Drive system plus or compatible (search the forums for a lively:D discussion on compatible fluids).
:mad: DO NOT USE HYTRAN!!!!! :mad:
Also, make sure that the pump bypass lever is not pulled out at all.
If you still have no forward/reverse, power steering or lift then the hydro is not pumping for $ome rea$on. (That's not a typo. It starts to get expensive at this point.:eek: )
Today I removed the snowblower, jacked the front up about 8", replaced the transmission filter, added fluid, and went through the bleed procedure by pumping the F/R pedals while the transmission was disengaged. Unfortunately, there is no change in the problem.
I was concerned that the hydro bypass spring plate might not be working right, so I removed it and used a wooden wedge to hold the button disengaged, and went through the bleeding again - after 40 pumps on each of the pedals, and removal of the wedge, I still have no hydraulics.
For others performing filter change, beware that the filter has a nipple that might come out with the filter and need to be transferred to the new filter. This cost me some lost oil, while I figured out I needed to plug the hole with some paper towels while I made the nipple transfer.
So I'm still scratching my head and looking for next step suggestions.
   / 3225 Hydraulics Problem #10
Peavs, You obviously know what you're doing around these tractors.
I'll admit right up front that I'm not sure that I follow how to tell if the drive shaft is driving the pump, but as long as "Rich D" does, that's good.
On a similar front, in the attached figure,
can the check, relief valves and/or plugs (#25-30) be used to figure out if there's anything going on inside the pump? I know it sounds dumb, but could someone undo one of these, disconnect the spark plugs and turn over the engine, then look and see if there's a puddle. I don't know what the fluid path is like, but is there a point that, if fluid doesn't come gushing out when the driveshaft is turned, it means that the pump is dead? If I know which way fluid flowed around the filter I might even think you could make a similar check there.
Yes, it's crazy - would it work?
2019 KUBOTA U35-4 EXCAVATOR (A52706)
2019 KUBOTA U35-4...
2014 SKYTRAK 10054 TELEHANDLER (A58214)
2014 SKYTRAK 10054...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
2016 Chevrolet Malibu Sedan (A59231)
2016 Chevrolet...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
2004 Ford E-350 Bus -6.0 Powerstroke Diesel - 55k Miles - Inoperable/Non-Running (A56438)
2004 Ford E-350...
