3320 and I want to add rear hyd. options?
   / 3320 and I want to add rear hyd. options? #1
offroadr
Central IL
JD 3320
I checked with my dealer and they told me the kit is $1300 DOH.
Is there a non JD alternative? No way am I spending that
   / 3320 and I want to add rear hyd. options? #2
is that just the kit cost, or does that incl labor??
when i was pricing a JD43xx tractor, they told me i could add the 1st rear remote for 950 including parts and labor.
i added the rear remote kit on my older JD870 for under $400 a few years back.
i wouldnt pay 1400 for a few hoses and 2 valves.
That was just the parts!
I did a search here but what I found most was people adding multiples to the rears they already had.
   / 3320 and I want to add rear hyd. options? #4
the Kioti i bought had one remote already included, and i had dealer add second one for $400.00 total.
when i shopped for a Deere, nothing was included. I hear that after the first one is installed, the rest are easy. you can even do it yourself real easy.
Im not sure if there is any after market kit available. especially since the mfg keep changing the styles so often.
theres a power beyond for JD 4000 series on ebay for $279.00 right now
http://cgi.ebay.com/John-Deere-LVB2...902?pt=LH_DefaultDomain_0&hash=item3cb50ba0be
and a 3120 power beyond lines.
http://cgi.ebay.com/John-Deere-Powe...788?pt=LH_DefaultDomain_0&hash=item4157306d7c
   / 3320 and I want to add rear hyd. options? #6
What year is your 3320? Is it O/S or Cab?
There are different options to achieve rear outlets. If you only want one more SCV perhaps you should ask about the LBV25506 version
Dual Mid & Single Electrohydraulic Rear SCV
Available only as Dealer-installed Option on 3320-3720 Model Cab with standard seat tractors.
7030
$855.00
Third Selective Control Valve Kit (Open Station Only)For 3120-3720 Tractors, Dual SCV is Standard.
Not compatible with MY2011 tractors. See sales
manual for details.
LVB25506
$244.00
Electric Diverter Kit (Open Station Only)Includes Diverter Valve, Two Sets of Rear Mounted
couplers, Hydraulic Lines and Selector Switch. Not
compatible with MY2011 tractors. See sales manual for details.
LVB25507
$1,299.00
Its an open cab model 2008 year.
   / 3320 and I want to add rear hyd. options? #9
Well mine is a 2008 also. I custom ordered from the factory and don't remember the exact price, however, talk to your dealer regarding the $244 version. There are two ports on the back and a control lever that goes on the right fender right beside the 3pth lever.I believe the $1,300 version is for MY 2011 and includes the electronic diverter and is integrated into the dual mid SCV control. The ones I see now at the dealer store are totally different from mine.
   / 3320 and I want to add rear hyd. options? #10
If you only need one remote, then that kit is under $300. He quoted you the factory electric diverter and you may not need that. There are other options...but you need to tell us what you need the remotes for and how many you need.
2020 DRAGON ESP...
2013 VOLVO EC250DL EXCAVATOR (A60429)
2013 VOLVO EC250DL...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
WINCH CABLE DRUM (A58214)
WINCH CABLE DRUM...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
