Does your particular model have an outlet to the back? If so, there is a terminal in that plug that is only hot when the key switch is on, as well as a ground, the major plus being, in my opinion, not having to cut into the wiring on my tractor. I bought a plug at Tractor Supply to the tune of about 20 bucks and a couple blazer flood lamps for $40 each and ran wires out of the new plug up into the ROPS, put a switch in the ROPS just below where the hinge is, then ran the wires to the top of the rollbar, where I mounted the lights. With them so high, they cast a beam pretty much unobstructed, unless the loader's way in the air. If I Think of it I'll go out and take a few pics and put them up here to give you a few ideas.
Sent from my LGL35G using TractorByNet
