3320 w/ 300CX FEL won't lift and Dump??
   / 3320 w/ 300CX FEL won't lift and Dump?? #11
Re: 3320 w/ 300CX FEL won\'t lift and Dump??
My old 770 is the same way. I attribute it to the pump and valve system. Both functions simultaneously requires incredible amounts of flow and pressure at the same time, like big loaders and TLBs have available. Even then, you can see a difference in lift/dump speed as opposed to only one function at a time.
   / 3320 w/ 300CX FEL won't lift and Dump?? #12
This is the case on over half of Deere's loaders. They are using a cheaper valve that does not have the corner postition functions.
   / 3320 w/ 300CX FEL won't lift and Dump?? #13
Which half?
   / 3320 w/ 300CX FEL won't lift and Dump?? #14
<font color="green"> Which half? </font>
Well Mike, the "OTHER" half, of course! You should have guessed that. /forums/images/graemlins/wink.gif
   / 3320 w/ 300CX FEL won't lift and Dump?? #15
It took some digging, but here is the story I got. John Deere hooks up the loader raise and dump cylinders so that they are in parallel when the operator tries both functions at once.
The result is that the function requiring the lowest pressure to operate wins and takes all the flow. When lifting and dumping simultaneously, the dumping will get all the flow until the dump cylinders are fully extended, then the lift cylinders can get enough pressure to lift.
Kubota on the other hand put the lift and dump cylinders in series when both functions are selected by the operator. The flow exiting the lift cylinders is then directed to the dump cylinders so that both can operate at the same time.
The John Deere parallel circuit has the advantage when trying to breakout a load by both lifting and rolling back the bucket because the full tractor hydraulic pressure is available to both functions and one will usually move. But when lifting and dumping you have to alternate from one function to the other.
In the same situation with the Kubota, applying both lift and rollback to the valve may not give any results with a heavy load because the lift pressure requirement gets added to the rollback pressure required and that may exceed the relief pressure of the hydraulic system. Then you are forced to alternate between lift and rollback to get full pressure to each.
So, which is better? I guess that's why competition and sales people exist! Each can decide to fit their own needs.
Having operated both John Deere and Kubota tractors with loaders in the past, I have to admit that I never noticed the difference until this discussion came up. The type of jobs that I have done haven't involved dumping and lifting. Usually I just dig up dirt and dump it in a pile. If I want to spread it, I have gotten o.k. at backblading. And I guess I figured out how to get good performance out of both the John Deere and Kubota without thinking about it.
   / 3320 w/ 300CX FEL won't lift and Dump?? #16
my 3120 with 300CX seems to raise and dump fine..
   / 3320 w/ 300CX FEL won't lift and Dump?? #17
Compare Roger's and Messick's posts. Sure is helpful to have a Kubota Dealer answer questions in this forum, isn't it? /forums/images/graemlins/tongue.gif
It appears you know the scoop here. My dealer also mentioned that some of the olders models (4-5 yrs back) didn't have this issue...
Not sure where your source is on this, but it really doesn't seem correct. These Deere loaders will do all simultaneuos functions EXCEPT lift and dump. That leads one to beliveve there is no problem with the pump or loader keeping up, rather it appears there is a SCV valve issue as per Messik's post above.
As far as the kubota not having as much break out force, it might be true, I just haven't noticed it. FYI, the Deere lift and dump problem occurs under no load conditions as well....
   / 3320 w/ 300CX FEL won't lift and Dump?? #20
I touched on this in a different post, so I thought I should add the information here. I tested two tractors. A 3120 with a 300X and a 3320 with a 300X. They both had the same problem. They could do all simultaneous actions except lift and dump. I have the JD 2005 COMMERCIAL & CONSUMER EQUIPMENT PURCHASING GUIDE and on page 44 for the 300 series loaders it reads </font><font color="blue" class="small">( Loader boom and bucket functions operate through the tractor hydraulic system. The control is integrated into the tractor operator platform for easy operation. Allows simultaneous boom/bucket function using the loader control.)</font>
Last time I checked, simultaneous meant "at the same time". It seems to me JD needs to own up and address this issue.
Doug
2016 Chevrolet Tahoe SUV (A55853)
2016 Chevrolet...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
Mahindra 6065PST (A53317)
Mahindra 6065PST...
2007 Ford Expedition EL Limited 4x4 SUV (A53424)
2007 Ford...
1996 Allegheny 35ft 25 Ton Flatbed Equipment Trailer (A51692)
1996 Allegheny...
