3320 w/ 300CX FEL won't lift and Dump??
/ 3320 w/ 300CX FEL won't lift and Dump?? #1
Jomo45
SW Missouri
3320 w/ 300CX FEL won\'t lift and Dump??
I have about 35 hrs on my new 3320, 300CX, heavy bucket and have a problem lifting and dumping at the same time. My neihbor has the exact tractor and exact same problem. When trying to lift and dump (right and back) the loader will barely move. The dealer says this is normal, all the other tractors I have used didn't work this way (incl my dads new Kubota 4330!) Anyone else experiencing this? Thanks!
/ 3320 w/ 300CX FEL won't lift and Dump?? #2
Re: 3320 w/ 300CX FEL won\'t lift and Dump??
My 3720 will lift and dump at the same time but the lift is slow while dumping and the dumping is slow also (much slower than doing one action at a time). I don't see it as a problem as if you get trying to do things too quickly thats where trouble comes in. In the past month of owning my 3720 I have had several severe pucker factor incidents due to trying to go too fast doing something (like lifting and dumping while moving). Hope this helps......
Shooter
/ 3320 w/ 300CX FEL won't lift and Dump?? #3
My 3320 with 300cx is the same. My dealer sells J.D. and Kubota. We put the 3320 next to a L3400 and checked lift and dump rate, starting both loaders from ground level. The 3320 was faster. The L3400 could lift and dump at the same time and rate, the 3320 could not. My salesman pointed this out to me. He also pointed out the fact that the 300cx had a 1 ft. higher lift capability over the Kubota.
Thanks for your input! I am a little unclear, are you saying that the 3320 won't do the lift and dump at the same rate as the Kubota? That is my neighbor and I's experience. If I just do one function at a time the speed is excellent, and it slows for lifting and curling, lower and curl, or lower and dump, but this is an acceptable speed. It is only the lift and dump that goes to super slow motion... The dealer is now wanting to bring a Deere Rep out to look at our tractors, he isn't holding out much hope though...
I also agree, too fast gets me into trouble!! The problem I am experiencing is that the lift and dump combination is so slow it is basically unuseable. When spreading material it is nice to be able to move forward or backward while lifting and dumping, I currently must have zero ground speed.... kinda defeats the purpose of the hydro...
/ 3320 w/ 300CX FEL won't lift and Dump?? #6
My dealer pointed out to me, that the front loader would not dump the bucket at the same time the arms were going up or down. He said it must have something to do with the hydraulic valve set up. Maybe Deere designed it that way because the hydraulic pump could not keep up otherwise. That was just his guess, he really couldn't explain it. I had the front bucket at full height, then pushed the joystick forward to lower, held that position and pushed stick to full right. It would not rotate the bucket to dump. I would like to know why as much as you. Please let me know if you find out. I haven't found it to be that much of a problem in actual everyday use. cruzr
Sounds like you have seen the exact issue my nieghbor and I are dealing with, I suspect it affects most or all 3320's. These tractors have dual pumps and should have no problem doing two functions at once, in fact they will do the other dual operations, just not the simultaneous lift and dump operation. I am fairly certian this is an adjustment issue or design flaw in the SCV valve, it just isn't opening the flow properly for simutaneous lift and dump. I definitely agree with you that the Deere should do anything a Kubota can, only better! (I actually am very pleased with this tractor other than the loader problem)
/ 3320 w/ 300CX FEL won't lift and Dump?? #8
Wow, the 3320 is rated at 13.9gpm, the Kubota 3130 shows 11.7 but then the cylinder sizes could make a difference. Now a 4330 could easily outclass the 3x20, but that is a different frame size. I haven't had any issues like this with my 4310...
/ 3320 w/ 300CX FEL won't lift and Dump?? #9
Have any other 3x20 series owners noticed what we have described, with your loaders? Now I'm wondering if it is the same with the 300x loaders also? Hopefully some John Deere exec. or rep. browse's the forum and can answer our questions. /forums/images/graemlins/grin.gif
My dealer has indicated that it is inherent in all 3X20, and possibly 4X20 tractors..... I might not have noticed the problem if I hadn't spent quite a few hours on my Fathers two Kubotas, they definitely do not have the same problem. I really got used to moving and dumping at the same time, this is a real time saver when spreading several loads of dirt or rock... (although I don't care for the treddle peddle for the Kubota hydro, Deere's set up is much better!)
/ 3320 w/ 300CX FEL won't lift and Dump?? #11
My old 770 is the same way. I attribute it to the pump and valve system. Both functions simultaneously requires incredible amounts of flow and pressure at the same time, like big loaders and TLBs have available. Even then, you can see a difference in lift/dump speed as opposed to only one function at a time.
/ 3320 w/ 300CX FEL won't lift and Dump?? #12
This is the case on over half of Deere's loaders. They are using a cheaper valve that does not have the corner postition functions.
/ 3320 w/ 300CX FEL won't lift and Dump?? #13
Which half?
/ 3320 w/ 300CX FEL won't lift and Dump?? #14
<font color="green"> Which half? </font>
Well Mike, the "OTHER" half, of course! You should have guessed that. /forums/images/graemlins/wink.gif
/ 3320 w/ 300CX FEL won't lift and Dump?? #15
It took some digging, but here is the story I got. John Deere hooks up the loader raise and dump cylinders so that they are in parallel when the operator tries both functions at once.
The result is that the function requiring the lowest pressure to operate wins and takes all the flow. When lifting and dumping simultaneously, the dumping will get all the flow until the dump cylinders are fully extended, then the lift cylinders can get enough pressure to lift.
Kubota on the other hand put the lift and dump cylinders in series when both functions are selected by the operator. The flow exiting the lift cylinders is then directed to the dump cylinders so that both can operate at the same time.
The John Deere parallel circuit has the advantage when trying to breakout a load by both lifting and rolling back the bucket because the full tractor hydraulic pressure is available to both functions and one will usually move. But when lifting and dumping you have to alternate from one function to the other.
In the same situation with the Kubota, applying both lift and rollback to the valve may not give any results with a heavy load because the lift pressure requirement gets added to the rollback pressure required and that may exceed the relief pressure of the hydraulic system. Then you are forced to alternate between lift and rollback to get full pressure to each.
So, which is better? I guess that's why competition and sales people exist! Each can decide to fit their own needs.
Having operated both John Deere and Kubota tractors with loaders in the past, I have to admit that I never noticed the difference until this discussion came up. The type of jobs that I have done haven't involved dumping and lifting. Usually I just dig up dirt and dump it in a pile. If I want to spread it, I have gotten o.k. at backblading. And I guess I figured out how to get good performance out of both the John Deere and Kubota without thinking about it.
/ 3320 w/ 300CX FEL won't lift and Dump?? #16
my 3120 with 300CX seems to raise and dump fine..
/ 3320 w/ 300CX FEL won't lift and Dump?? #17
Compare Roger's and Messick's posts. Sure is helpful to have a Kubota Dealer answer questions in this forum, isn't it? /forums/images/graemlins/tongue.gif
It appears you know the scoop here. My dealer also mentioned that some of the olders models (4-5 yrs back) didn't have this issue...
Not sure where your source is on this, but it really doesn't seem correct. These Deere loaders will do all simultaneuos functions EXCEPT lift and dump. That leads one to beliveve there is no problem with the pump or loader keeping up, rather it appears there is a SCV valve issue as per Messik's post above.
As far as the kubota not having as much break out force, it might be true, I just haven't noticed it. FYI, the Deere lift and dump problem occurs under no load conditions as well....
/ 3320 w/ 300CX FEL won't lift and Dump?? #20
I touched on this in a different post, so I thought I should add the information here. I tested two tractors. A 3120 with a 300X and a 3320 with a 300X. They both had the same problem. They could do all simultaneous actions except lift and dump. I have the JD 2005 COMMERCIAL & CONSUMER EQUIPMENT PURCHASING GUIDE and on page 44 for the 300 series loaders it reads </font><font color="blue" class="small">( Loader boom and bucket functions operate through the tractor hydraulic system. The control is integrated into the tractor operator platform for easy operation. Allows simultaneous boom/bucket function using the loader control.)</font>
Last time I checked, simultaneous meant "at the same time". It seems to me JD needs to own up and address this issue.
Doug
1979 Ford F-100 Ranger Pickup Truck (A59230)
1979 Ford F-100...
2002 Frieghtliner Pressure Digger Truck (A55973)
2002 Frieghtliner...
2010 VOLVO A30E OFF ROAD DUMP TRUCK (A60429)
2010 VOLVO A30E...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER TRUCK (A59905)
2019 INTERNATIONAL...
KBH Tank Trailer (A61307)
KBH Tank Trailer...
UNUSED FUTURE EQUIPMENT SEAT (A60432)
UNUSED FUTURE...
