3325 with 78 hours won't start
   / 3325 with 78 hours won't start #1
DonWorrell
Pleasant View, TN
Mahindra 3325
My 3325 will be 3 years old July 2009. I put a new battery in the tractor a month ago. I put in what was called for by the manufactor. It started and ran well.
I went out last evening and tried to start it. I put everything in netural turned on the key all the lights turned red as they should. It turned over once or twice or about 2 seconds then it went dead. All the lights and gagues are dead.
What could possibly be wrong?
Don
   / 3325 with 78 hours won't start #2
How about your head lights, do they come on? You might also have your battery checked at some auto store under a load to make sure it's still good and how about the battery connectors are they good? Really sounds light a dead battery or one that's not being recharged correctly. Have you measured the battery?
   / 3325 with 78 hours won't start #3
Dead Battery, check connections, give it a charge and see what happens.
   / 3325 with 78 hours won't start #4
Don
Battery not charging is my guess.
Why?
Bad cell (it happens occasionally with new batteries--infant mortality).
Problem in the battery charging circuit -- blown fuse, alternator problem, voltage regulator.
Put the battery on a charger for 24 hours and see if you can get started. If not, take the battery back and get it tested. Should be under warranty.
   / 3325 with 78 hours won't start #5
First check the battery connections at both ends of the cables.
   / 3325 with 78 hours won't start #6
I agree with Galen. If the battery and connectiions chek to be in good working order, it could be the 30 amp "Max Fuse". If this fuse is blown, it would cause the same symptoms that you are experiencing.
Scott@Artec
I found he problem. I left the head lights on. I put a trickle charger on the battery. After the battery charged the tractor started right up. It has started everytime since.
The 3325 is still a problem free machine. Operator error is the only problem I have had in three years.
Don
   / 3325 with 78 hours won't start #8
yep sometimes it is the simple things that get you:D
   / 3325 with 78 hours won't start #9
Don,
Are you sure that's the problem? On my 3525 (2007 model), all of the lights go through the ignition switch... nothing's on the "hot bus", so to speak. I would assume (but I know what happens when you do that :rolleyes:) if you turned the key off, the lights should have gone out as well. I would think that with the 3325 and 3525 being so similar, the wiring would be identical. But, maybe not.
And, 78 hours in 3 years? Get out there and work that thing!! :p
2011 Chevrolet Silverado 2500 Pickup Truck, 127808 Miles, Utility Rack - GREAT WORK TRUCK (A56438)
2011 Chevrolet...
EXCAVATOR RIPPER (A58214)
EXCAVATOR RIPPER...
2006 Ford F-750 Fuel and Lube Truck (A59230)
2006 Ford F-750...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
25 TANDEM DUAL GOOSENECK TRAILER (A55745)
25 TANDEM DUAL...
2020 CATERPILLAR 306 CR EXCAVATOR (A60429)
2020 CATERPILLAR...
