3550 hst problems,cheap built,lemon?
   / 3550 hst problems,cheap built,lemon? #81
Dave, I have the shaft and am going to look at it with a microscope and look for banded tempering markings indicative of induction tempering problem. Will investigate the propagation of the crack origination and machining imperfections. Right now I'm thinking of a name for the cantankerous tractor. It is dissapointing, but I have never used such a comfortable tractor.
   / 3550 hst problems,cheap built,lemon? #82
Update: Mechanic came to farm and saw a puddle of fuel on floor. He tightened a fitting. Also had to bypass a couple of sensors with his diagnostic tool to get it running. My dad is going to use it this afternoon to get one more field cut. Cross you fingers.
That's one reason that every shop needs a dyno. After a repair, you can run the snot out of it for 1/2 hour or so and often if you are going to have a leak, it will show up under load with a warm engine. Basically, you mimic the customers usage and eliminate a lot of callbacks and disappointments. Before we had our dyno, we would put a large mower on a tractor and look around the neighborhood for some tall grass. But after a while, you can't find any...it's all cut! A dyno is easier. You see old dyno's for $2500 sometimes. New ones are 10x that, but you do not need a new one or even a certified 100% accurate machine just to load up a tractor.
Sounds like the dealer is responsive and will get this fixed. It is an impressive tractor when running as designed. BTW, I sold one to a buddy a few years back (the 5035, really similar but without the fancy engine controls) and he has yet to have a problem with it. Sold a 4035 to another friend and it's been really reliable except we had to swap out the fuel hoses. And he uses it hard. Once the kinks are worked out, I'm hopeful you will have years and years of good service. Other brands with DPFs are having quite a few issues. You are avoiding DPF issues, if that is any consolation.
   / 3550 hst problems,cheap built,lemon? #83
If it's a fuel leak while sitting, it might not show up while running since the fuel system is under vacuum. Little bubbles will be pulled in along with the fuel, which won't be apparent until it is shut off and the system loses prime. I would also check the fuel cap to make sure it is not completely sealing the tank - I have had issues multiple times with mine, and I know my dealer has replaced a few collapsed tanks. The tractor starts very hard if there is a vacuum in the tank. If you combine a small air leak in a fuel line with a fuel cap that does not vent, you could easily have a no start condition.
Theoretically, Mahindra was designing a better cap, but I haven't heard anything further on it. 3550hst, make sure you leave the cap a little loose to allow air into the tank as fuel is used.
   / 3550 hst problems,cheap built,lemon? #84
How about Cranky.
   / 3550 hst problems,cheap built,lemon? #86
Thanks, guys. I really appreciate the advice. I do think that the mrcde engine is a bit more complex. It may take tractor mechanics a while to work with these babies.
   / 3550 hst problems,cheap built,lemon? #87
Hey everyone. It has worked for a number of days and starts quickly. Horsepower is greatly improved too. Before the fix, only low range could get it up hills. Now it doesn't lose too much rpm at 20 percent grade.
   / 3550 hst problems,cheap built,lemon? #88
That is encouraging. Sounds like it is running as designed. Finally.
   / 3550 hst problems,cheap built,lemon? #89
Yes, good news! I've been watching this thread closely as I am most certain that when I buy, I'm getting a 3550 but with the PST transmission. Thanks for the updates and make sure you let everyone know what the drive shaft failure analysis reveals.
   / 3550 hst problems,cheap built,lemon? #90
We got the HST transmission because the super easy driving. Don't regret it at all and doesnt seem to rob power. Using the bucket is 20 times easier with the HST. I thought I wanted shuttle shift, which is good, but the hst makes a lot of other things easier. On level ground (safety people are going to laugh) you can be off of your tractor and use your hand on the pedals to inch up to that 1000 pound cutter. It was super convenient when drilling holes to operate the drill standing on the ground. I lightly set the parking brake so I could position the auger to start. When the auger gets in the ground, you can inch backwards to keep it straight. For brush hogging HST is just plain better because of the speed control and the back and forth near woods. I hope this helps.
CAT Chassis Only (A59076)
CAT Chassis Only...
2015 Ford Focus Hatchback (A59231)
2015 Ford Focus...
2013 Ford F-250 4x4 Ext. Cab Pickup Truck (A60460)
2013 Ford F-250...
2020 Ford F550 - 6.7L Powerstroke Diesel -54k Miles (A56438)
2020 Ford F550 -...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A59231)
2014 Glasstream...
