Ballast 3720 wheel weights
/ 3720 wheel weights #1
xkbal
Bronze Member
Canada
JD 3720
Hi,
I'm looking to add wheel weights to my 3720. Checked with the dealer I bought the tractor at and am looking in the $1200 ballpark to add three 55 pound weights/side. This is a pretty pricy ballpark. Is that the going rate for these?
I could buy 2" sheet, waterjet/plasma, use the leftover circles for weight for my rear blade and have leftover for projects and still be cheaper than the Deere cast iron weights.
/ 3720 wheel weights #2
WAYYYY Bleepin high...
General rule of thumb on JD weights is about $1.00 per LB.
I had my tractor delivered with 2 weights each side, but If I were shopping, I'd say TOTAL Cost for everything should be right around $350.00 for everything. Keep in mind, this is a wholegood...its no different then buying your tractor, so you can dicker with them a bit....
What wheels you got, if you got r4's the following is what you need:
The wholegoods PN for the Weight on R4 Rims is:
BM17968 - 23.6KG (52 LB) (STARTER/ADDITIONAL WEIGHT) (USE WITH 15 - 19.5 OR 43 X 16 - 20 R4 TIRES)
To add 3 weights per wheel you'll also need (for each side):
LVB25004 - STARTER WEIGHT HARDWARE (INCLUDES PARTS MARKED (A)) (USE WITH BM17968)
and QTY 2
BM19337 - ADDITIONAL WEIGHT HARDWARE (INCLUDES PARTS MARKED (B)) (USE WITH BM17968)
Thanks for the info. He did say that I could get suitcase weights for about a $1/pound but I'll have to see what he can do on the price for the wheel weights. Maybe try a different dealer.
/ 3720 wheel weights #4
I bit on the dealer-supplied JD wheel weights when I bought my 3720. Big dissapointment. I could not access the wheel studs because the socket interfered with the inner diameter of the wheel weight. I removed them, replaced the mounting kit (80 dollar bag of bolts and spacers), with my own hardware, and machined the ID of the inner weight to allow access to the wheel studs. Good thing I did so, 'cause a couple weeks later I broke off the inflater stem and had to have on-farm service out in the woods. Not having to handle the weights saved a lot of hassle. It is possible my dealer's service dept assembed it all wrong, but in any case, I paid way too much for that bag of bolts. I have 110 lbs per wheel on there now and plan to add another 150 per wheel when I can get the machining done to these two old red weights I have laying around. I also would like to have two inch wheel spacers, but will have to turn them myself as I am too cheap to pay the price of purchased ones.
I like your idea of waterjetting out what you want. I looked up the weights and found to my surprise that cast and sheet steel weigh about the same.
/ 3720 wheel weights #5
Yeah that is the case....BUT to Deere's "defense"...and from my own point of view...
I would'nt want to remove & work on the wheel with the weights on it...I'm apparently not a strong as you :D because when I needed to remove my wheel, I removed the weights first...no need to fight with an additional 110 lbs for nothing...
What I'd really like to know is why we cant use the 110 lb weights on the R4's (#8 in the pic)
I'm pretty sure the OD is the same....
/ 3720 wheel weights #6
Well I am not saying it is easy to lift the wheel with the weights on it, BUT:
1. If you can leave them on there in case you have to pull the wheel it saves time. Two guys can easily stand up the wheel with weights on it. And if you can leave it standing and roll it out of the way for service, etc, then it is a one-person job.
2. Handling the weights and getting them aligned to put in the bolts is hard, and is MUCH easier with the rim laying on the floor flat. Then of course you must stand the wheel and be able to install and tighten the wheel studs afterwards.
3. You must check your wheel stud torque periodically. Its an easy task if you can reach the wheel studs. It totally sucks if you must handle the weights off there to do it and then back on afterwards.
/ 3720 wheel weights #7
Did you consider loading the rear tires with Rimguard? Depending on what size tires you have you can add approx 300+ lbs per tire and it is far less expensive than wheel weights. Some people use RV antifreeze. You can get away with using water if you live far enough south.
I looked into rimguard and it doesn't seem to be available in my area, it's possible it may not be able to handle the cold as it is possible to get to -40C here and not unusual for -30C. Had also considered ww fluid but would prefer wheel weights if possible. Unless I can find a better price I'll probably end up going with fluid of some sort.
Haven't had a chance to check back with my dealer yet as I work out of town and won't be back till next week.
/ 3720 wheel weights #9
XKbal : WELCOME ABOARD! The Canadian version of RimGaurd, (different company) called Eco Solutions in Milton Ontario. This is basically the same "beet-juice" that Rim Gaurd uses and in Canada its called "FUSION" and does NOT freeze till it gets down below -55c, then I believe it begins to slush up a bit. NO salt!
Anyway thats what I use in my tires, its heavier than water and if you have a leek it is enviro-friendly. I know they ship it all across Canada for use on highways in place of salt, and spray it on granulated open carloads being shipped from BC through the mountains by train to keep it from freezing.
Their website is : www.eco-solution.net This company does NOT specialize in filling tires, so If any of you are interested, I can give you a contact person and phone number. At least this gal will understand your needs and gladly answer your questions. You'll have to check it out, I have no idea if they'll ship it to you out there or if they have a dealer in your area?
Just a suggestion which I hope will be helpful.
. . tug
PS: IF you tried clicking on that website and didn't get it,.....try just typing in www.eco-solution.net That seems to bring it up no problem, sorry bout that.
/ 3720 wheel weights #10
I was quoted $128.00 per 60lb weightthisweekendformy 3032e. I can use & need 3 per side,so $768.00 + tax fromlocal jd dealer. A little over 2.00 a pound. .
Joe
/ 3720 wheel weights #11
JANDG : WELCOME ABOARD! ....and,.. er, .. ah,..what country are you in? Is that a US,..Canadian, European "Price",..please help me with that.
CHEERS!
. . tug
/ 3720 wheel weights #12
Anyway thats what I use in my tires, its heavier than water and if you have a leek it is enviro-friendly..... .
I'd just add that you likely will not need inner tubes if you use Rimguard equivalent so you can easily fix a tubeless tire with just a plug like on auto tires without even taking the wheel off the tractor.
/ 3720 wheel weights #13
Been there done that more than once...:)
/ 3720 wheel weights #15
Sunnyside360:...Yes, correct,.."no tubes required" for the "FUSION" (Canadian beet juice) and RimGaurd (US beet juice) great stuff! Thanks for that Sunnyside360,...slipped my mind.
JDGREEN4ME:... Thanks for that! (What else did I forget to mention?)
JANDG:...OK Joe,...WA State, USA and US$,...gotcha, thanks!
OH Yeah,....the "beet juice" stuff is brown, not red, it's sticky, but tastes sweet. How do I know? The valve adaptor slipped off,...I got wet and sticky but my clothes washed out with no problem,...my "Lady" put 'em through with a regular load,...just as easy as that!
CHEERS guys,
. . tug
. . tug
Thanks for the pointer, if you could send me the number and name I would appreciate it. Just got back home so am back on the search for something again.
Al
/ 3720 wheel weights #17
Hi Al,....just sent you a PM with the info,...but so far I can't seem to see any confirmation (as normal) that the message went out. Lots of computer problems here so could you please acknowledge "IF" you get it,...or not and I'll send again.
Thanks and good luck,
. . tug
PS: Ok checked again, it went, (sorry it went twice)
/ 3720 wheel weights #18
I posted some of the following on another thread regarding mid mowers, however most of my questions are side hill stability.
I am considering upgrading to a 3720 or 3520 tractor. My biggest concern on the 3000 series tractors is the narrow wheel track and total weight for side hill mowing stability. Currently my Deere 870 with loaded tires set to the wide wheel position and has a 64 outside wheel track that has proven to be adequate on my terrain.
The 3000 series brochure depicts a 68.4 rear track width. I have looked at a unit with the 43x16-20 R4 tires and that wheel track is about 57? I have reports that the turf special tires (41x18LL-16.1, R3) run about 64 wide but that tread would not be suitable for winter work here in PA.
1) Does anyone have front and rear track width measurement for a wide wheel track configuration with standard turf tires (41x14-20, R3) or the wider industrial tires (43x16-20, R4).
2) Anyone running a 72 mid mower on a wide wheel track setup?
3) Any real world comparisons of side hill traction for these two tire types?
4) Likewise, any comments on these two tire types relative to tearing up turf?
5) Are there wheel spacer kits available to widen the track on the front and/or rear for the 3000 series? P/Ns?
/ 3720 wheel weights #19
BriarCreek:
1. I'm running a 3720 (Soon trading on a 4720) with 6" (Each side) unverferth wheel extensions and loaded R3's in the 'narrow' position (Fronts wide). I'm about 66" wide in the rear (I'm not with the tractor so I can't measure the front). Without the extensions I'd be 54" wide, or about 59.xx" in the wide position - Still pretty narrow. The R4's run a little bit wider but the difference narrow/wide is only about 1.5" vs about 5" narrow to wide on the R3's.
2. I was running my 72" 7 iron and went to an 84" RFM - Enough Said. :)
It was a royal pain in the butt putting it on and off anyway, would lose adjustment,
you need to loosen the lead screw for the height adjustment all the way, etc.
With the wide stance it's even worse reaching underneath so I gave up.
If I could leave it on it would be fine, but taking it of for 'tractor' work was a pain.
My advice would be if you are going to leave it on for long periods of time the
MMM is ok. The cut quality of the MMM is superb and it doesn't scalp much.
If you have lot's of 'tractor' work I would go with a RFM. And if you are doing
ANYTHING but scooping up stuff on level ground with the loader on you will be
banging up that expensive deck. (Note that it is pretty rugged and I never
bent anything badly on it but would throw it out of adjustment a lot.)
3. I ran my 3320 (No wheel extensions) with the MMM with the large R4's and had
unloaded large R4's on my 3720 when I got it.
I mow sideways a bit up to about a 15 degree slope. Both
tires are ok but the R3's are actually much better on firm, dry ground. You can
spin the R4's easily on hard packed turf if you are going straight up and down
in 2wd. (Note that I run that now with the extensions, I'd be leery running a 15
degree slope without them even I know it would be ok).
4. The R4's will leave compression marks on the lugs. The R3's just pat down a
wide swath but don't compress or leave marks in the soil. Note that I mow at
about 6000lbs in my 3720 (loader on/bucket off).
Both tires will tear up the turf if you cut sharp even in 2wd. Keep the turns
gradual and you'll be ok.
I've found the R3's to be a better all around tire than the R4's but note that I
don't trek through the mud a lot. In hard pack snow and on ICE the R3's
are way, way, way better than the R4's. The R3's also support Chains better
since they don't 'fall' in the lugs.
5. - See 1. Yes, Unverferth. I forget what they were (I think a little under $300
each).
/ 3720 wheel weights #20
Briar:
FYI, if you download the owners manuals (Available from the description pages on-line) the dimensions in those are pretty accurate.
