3PH arms won't raise on KAMA 454
   / 3PH arms won't raise on KAMA 454
Sound Guy,
He is a good friend and I don't blame him. Because I was in a hurry, I just put the yard box at his house.
Well, Chip quickly sent the replacement PR valve and I installed it while draining and flushing for the 50 hr service. I did not notice anything out of the ordinary. But needless to say no change. Lift arms only work when I bump the FEL controls.
Now that has been eliminated, what could be the next to look at/change?
   / 3PH arms won't raise on KAMA 454 #13
With the lift box hyd tank empty, could you see how the cams work on the lift valve plunger? did eveything appear to be functioning? This has got be a bit baffled. I sure do hate admitting this on a public forum!
   / 3PH arms won't raise on KAMA 454 #14
I noticed if my loader is in float and I raise the lift that the loader raises. sounds like the reverse is happening here.
Chip,
I did move the Draft and position lever to see how this works. The plunger goes in/out smooth. Is the plunger a valve of sorts? Could this be the issue? I did take photos but it does not show much.
Tires (A50322)
Tires (A50322)
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
RCcar RC-G2.0 Electric Golf Cart, NEW! (A52384)
RCcar RC-G2.0...
Valvoline 80//90 Gear Oil (A53117)
Valvoline 80//90...
UNUSED WOLVERINE BC-13-72W-72" HYD BRUSH CUTTER (A51248)
UNUSED WOLVERINE...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
