3PH arms won't raise on KAMA 454
   / 3PH arms won't raise on KAMA 454
Sound Guy,
He is a good friend and I don't blame him. Because I was in a hurry, I just put the yard box at his house.
Well, Chip quickly sent the replacement PR valve and I installed it while draining and flushing for the 50 hr service. I did not notice anything out of the ordinary. But needless to say no change. Lift arms only work when I bump the FEL controls.
Now that has been eliminated, what could be the next to look at/change?
   / 3PH arms won't raise on KAMA 454 #13
With the lift box hyd tank empty, could you see how the cams work on the lift valve plunger? did eveything appear to be functioning? This has got be a bit baffled. I sure do hate admitting this on a public forum!
   / 3PH arms won't raise on KAMA 454 #14
I noticed if my loader is in float and I raise the lift that the loader raises. sounds like the reverse is happening here.
Chip,
I did move the Draft and position lever to see how this works. The plunger goes in/out smooth. Is the plunger a valve of sorts? Could this be the issue? I did take photos but it does not show much.
2011 Wacker Neuson RD12A, 36" Double Drum Roller (A52384)
2011 Wacker Neuson...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
2002 Ottawa 30 Spotter Truck (A52384)
2002 Ottawa 30...
1992 International F-4900 Grapple Truck (A51692)
1992 International...
1989 Ford FT900 T/A Cab and Chassis Truck (A51692)
1989 Ford FT900...
2010 Ford Focus Sedan (A51694)
2010 Ford Focus...
