3PH arms won't raise on KAMA 454
   / 3PH arms won't raise on KAMA 454
Sound Guy,
He is a good friend and I don't blame him. Because I was in a hurry, I just put the yard box at his house.
Well, Chip quickly sent the replacement PR valve and I installed it while draining and flushing for the 50 hr service. I did not notice anything out of the ordinary. But needless to say no change. Lift arms only work when I bump the FEL controls.
Now that has been eliminated, what could be the next to look at/change?
   / 3PH arms won't raise on KAMA 454 #13
With the lift box hyd tank empty, could you see how the cams work on the lift valve plunger? did eveything appear to be functioning? This has got be a bit baffled. I sure do hate admitting this on a public forum!
   / 3PH arms won't raise on KAMA 454 #14
I noticed if my loader is in float and I raise the lift that the loader raises. sounds like the reverse is happening here.
Chip,
I did move the Draft and position lever to see how this works. The plunger goes in/out smooth. Is the plunger a valve of sorts? Could this be the issue? I did take photos but it does not show much.
2017 KENWORTH T800 (INOPERABLE) (A53843)
2017 KENWORTH T800...
2019 Fecon BH74SS Hydraulic Mulcher High Flow Skid Steer Attachment (A51691)
2019 Fecon BH74SS...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2003 Ford F-150...
2025 CFG Industrial MX12RX (A50123)
2025 CFG...
2020 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A52705)
2020 PRINOTH...
2023 Bobcat T66 (A50120)
2023 Bobcat T66...
