3pt forks or front bucket
   / 3pt forks or front bucket #1
Leejohn
Elite Member
Doniphan, Mo.
Kubota L4240, B7800 & BX2660
Made this last week. Worked great with the forks, but when I tried to pick up some gravel with the bucket on the back I bent the 1/2" strap for the lower pins. I was thinking I would need a little more room when it came to hooking up so I when 4" long on them. I was wrong because the frame is all open, also they should of been 3/4" stock and only need 2" from the frame.
Had to get stright and weld in a helper bracket to the inside, hope that does it. Shouldn't be needing it for grading anyways. Made it for moving my fire wood on skids.
Sorry I couldn't down size the pictures for the guys on dial up, using Vista on this computer and haven't found out how to to it yet.
   / 3pt forks or front bucket #2
Careful there, don't try lifting that poultry without proper ballast on the other end.;)
Looks good, though. I have thought about something like that, but I think that what I really need is a set of three point forks so I can move two pallets at once.
   / 3pt forks or front bucket #3
Just do a search online for Image resizer for windows. Its a free download. I use it on 2 computers using Win 8 and Vista.
Thanks!!! I'll check see if I can find it. Sure need it.
   / 3pt forks or front bucket #5
Pretty slick!
George2615
I looked for Image resizer for windows and there was alot and I didn't know a safe one to down load it. What one did you download? Thanks, Lee
2005 PETERBILT 379 TRI AXLE  DUMP TRUCK (A59575)
2005 PETERBILT 379...
2019 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A59905)
2019 INTERNATIONAL...
2017 HAMM HD+140I DBL DRUM ROLLER (A60429)
2017 HAMM HD+140I...
207272 (A52708)
207272 (A52708)
(INOP) 2007 VOLVO A35D OFF ROAD DUMP TRUCK (A60429)
(INOP) 2007 VOLVO...
2018 MACK CHU613 (INOPERABLE) (A58214)
2018 MACK CHU613...
