3pt top link tilt w/ electric actuator
   / 3pt top link tilt w/ electric actuator #1
Twanger
KCMO
4310 4wd ehydro 420 loader asof 4/2/02
Does anyone have an interest in an actuator that can run on 12vdc and provide top link adjustment? No hydraulics
   / 3pt top link tilt w/ electric actuator #2
I'll bite. Sure, I'm interested. What do you have?
   / 3pt top link tilt w/ electric actuator #4
I've considered it and even found some online (linear actuator). Seemed to handle the lifting load for a couple hundred bux but was concerned with impact load like when snaging rocks with a box scraper ...
We're listening /forums/images/graemlins/wink.gif
   / 3pt top link tilt w/ electric actuator #5
I wonder if an electric linear actuator could withstand the forces of tension and compression that the top link might see.
The ones I've seen look way too light duty and they tend to have a short lifespan.
It just seems like the wrong tool for the job.
Sorry I was out yesterday and attachments seemed to be broken when I checked. Here is a link I was looking at:
http://www.nookindustries.com/CCactuator/CCactuator_12VDC.cfm
Just a thought. This would simply let you adjust tilt with no load. I mean you could have an attachment on but not engaged in the ground.
Thoughts???
   / 3pt top link tilt w/ electric actuator #8
What about price? I have a Bobcat snowblower that uses a linear actuator for the chute deflector. Unfortunatly it was busted when I bought it. Cost new from the manufacturer is >$600. I have seen a bunch on ebay go for a lot less, but you have to watch out for the specs.
   / 3pt top link tilt w/ electric actuator #9
have seen some car jacks for flats that plug into the cig lighter. motor runs scissor jack. the jack would take the beating the 3 pt. would dish out so a hefty jack could be adapted to to take a fairly light motor. the mech advantage would put little strain on the motor. thoughts?
   / 3pt top link tilt w/ electric actuator #10
Some jacks built as jacks and not actuators are strong in only one direction. For example, trailer tongue jacks have bearings and support for compression and not tension. Top links need strength both ways.
Something more to think about when planning.
Bruce
JOHN DEERE Z960M LOT NUMBER 102 (A53084)
JOHN DEERE Z960M...
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
Pop up camper (A51694)
2018 Challenger 1042 Tractor (A53342)
2018 Challenger...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A53472)
2020 New Holland...
(INOP) NEW HOLLAND L328 WHEELED SKID STEER (A51242)
(INOP) NEW HOLLAND...
