3R Home and Barn Project
   / 3R Home and Barn Project
john_bud said:
Have you thought about a hydraulic winch? Put a cable choker on the trees and yank them babies out!
jb
Great idea John, we did think of that for the next trip up.
Only I don't have a hydraulic winch. But I do have a come-a-long which is probably too wimpy. Then I have about 10 ratcheting chain binders too that might work. I've even used a 3 ton overhead block and tackle for sideways jobs, even though you're not supposed to. But you're on the right track. Once we get them popped out, dragging them will be easy. It's just walking back up that slope that's a killer! All that exercise is bad for my smoking!:)
Scotty,
I'm glad you liked those videos.
You see why I doze in reverse like that? I know I get a lot of flack for it here, though.
Excuse my dumb question, but what is a SCBA? Oh, never mind...it's stumped me without the "U" in it. hahaha.
   / 3R Home and Barn Project #162
jb
Yea Rob I'm sure you could build one in your sleep!
tom
tom
Uh Tom,
I'm not sure man. It would probably flip my Kama over?:)
Hey whenever you get out West, you have to come by my place. I could use some of your electronic gadget wizardry.
Oh, another thing... is it starting to cool off back East now? It never got over a hundred all weekend, so Fall is right around the corner for us here.
   / 3R Home and Barn Project #164
EddieWalker said:
You really make the box blade look like a valuable tool. Mine is just a regular box blade without any of the fancy hydralics, so I don't ever use it. Seeing what you can do with it makes me wonder if I'm missing out on something? Naw!!! hahahaha
Eddie - see! This is the kind of stuff I was reading here when I decided that I just had to have one!! :D Rob makes this stuff look so easy, but after only a couple nights using mine I can really appreciate the skill of the operator, and the mod's he's made to his. Of course reading your lake thread made me want a dozer too, but the BB fit my budget a bit better.
Rob - if you get a chance can you shed some light on when you decide to use that thing in dozer mode Vs. cutting mode? I do understand not using the scarifers up there given the stuff you might run in to. I'm just spreading out some dirt mounds from where we cleaned out a pond a couple years ago, but have been very conservative in dozer mode. Seeing some of the work you've done I can see some potential advantages to the dozer mode when used properly.
Awesome work, great pics and vids! Inspiring. :)
   / 3R Home and Barn Project #165
Just remember that he has reinforced his lift arms due to already having bent them, unless I am mistaken...
Stablizers might help in the bull dozing mode, but I don't have them, so I can't say for sure.
David from jax
Yeah, David is right.
I've reinforced my lower drag links so they don't bend anymore. I also have solid but adjustable sway links that help greatly in the rear dozer mode.
Hey Tim,
I'll try...
I don't use the rippers especially going down trails cause if they catch on something, the tractor keeps spinning the tires and next thing you know you are facing sideways. I'm hoping the box will "jump over" some of those unseen obstacles. Then I can go back and get them with the toothbar and grapples or even with the boxblade again, but in a better position.
When do I bulldoze in reverse?
Keep in mind that a lot of my property is as you see in those photos, so I'm dealing with moderate to severe side slopes. So this explanation has those conditions in mind.
Well, if the area I want to cut has a severe side slope to it, then I try to bulldoze in reverse. I do this because the tires of the tractor generally end up riding on the surface I just cut. It then, is generally less sloped than before and also smoother than before. That means the tractor itself is on less of a side slope and safer. Here is an example of a rear cut. You can see how the cut is at a lesser side slope than before.
Look below where my tires are now. They are on more level and smooth stuff.
Not only that, but say you have a pretty good drop off and you want to level it or cut it down for a road. If you go forward, dragging the boxblade behind you, your tractor is doing an "endo" going straight down hill. If you bulldoze in reverse, you are making a road for your tires to follow. It might take a couple passes, but if done correctly, your tractor can continue in reverse right down that new cut road, like this.
See how I can keep going because dirt is being pushed back, giving me a road? Otherwise it would be a drop off.
Not only that, but there is a wall of dirt that keeps me from losing control and speeding down the hill. I can see my blade full of dirt behind it because I'm looking in the same direction. When going forward down hill, you have to assume you have a box full of dirt because your eyes are peeled ahead of you as you approach that super steep hill going down...or at least they should be. So you can't keep an eye on the boxblade.
When you are pulling a boxblade, your tires (ahead of the box) are on a side slope. Even if you have your side links adjusted so one side of the box is lower, your tractor tires are still on a side slope. This is not the safest positon.
Having two hydraulic side links really helps in making instant adjustments too. I'm pretty sure you will be getting them and a hydraulic top link too.:)
I hope some of this stuff makes sense.
   / 3R Home and Barn Project #167
That is great and all makes sense. In what I'm doing I don't have many of the same safety issues you do, very small mounds, not steep hills. The one thing that I do like is the idea of the tires riding in the newly leveled path rather than the BB just following the terain with your tires. Not as big of an issue with your set-up as mine.
The other frustrating thing is that as I approach a high spot, the front end goes up, the blade is resting firmly on the ground and takes a deep bite in front of the high spot. Then as the front end goes over the top, the BB swings up and fails to take the top off the hill, if there's another one just past it the front end goes up again, the BB swings down and takes a bite out of the valley. The thing is worse than when you started. Dozing the top off that sucker would seem like a great alternative.
Incidentally, I doubt I'll just be "getting" those hydrolic arms any time soon since I can't throw something like that together the way you can in your sleep. So when are you going to start selling them on Ebay, and will you paint them blue??? :D
   / 3R Home and Barn Project #168
3RRL said:
Larry G, do you remember getting on the rock bluff and looking down over them?..........SNIP..........
Oh yes, it's quite a drop off alright. Your Kama looks like some sort of alien insect with the mandibles munching away at the vegetation:
3RRL said:
So your going to burn all the slash you rip out of there? seems kind of dangerous, Can I light the match ;) I hope your still considering a chipper?
Larry
   / 3R Home and Barn Project #169
A chipper isn't that hard to build as long as you don't need it to do too much at a time.
David from jax
A chipper is in the future plans for sure after seeing what yours can do Larry.
I've never done a burn pile before and it scares the heck out of me. I'm going to start with teenie weenie piles first to see how it goes. I've got a lot to burn but have to wait until Winter before they allow any burning out here.
I've been looking at those hydraulic winches to yank the rest of those Buckbrush on the hillside. Any suggestions on that?
What about using a PTO powered winch? Is there such a thing? I have a huge 100+hp gear box sitting on my floor that I was going to use for a trencher attachment. It has one drive shaft and 2 axle shafts with a 1.33 to 1 reduction ratio. I'd need a slip clutch or something if it got over loaded so I don't break my 50hp PTO.
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2022 JOHN DEERE 6120M LOT NUMBER 191 (A53084)
2022 JOHN DEERE...
2010 MULTIQUIP 25KW GENERATOR (A53843)
2010 MULTIQUIP...
2004 Workhorse W22 Motorhome (A55758)
2004 Workhorse W22...
BOAT MOTOR TRAILER (A53424)
BOAT MOTOR TRAILER...
