3RRL
Super Member
- Joined
- Oct 20, 2005
- Messages
- 6,931
- Tractor
- 55HP 4WD KAMA 554 and 4 x 4 Jinma 284
Here's how I did that.
Once I managed the tank down, I had to reposition the straps so they were on the top end of the tank. This was a tricky operation. I needed to tilt the tank upright very slowly with the Gradall until it would right itself. The tank is super heavy too, like about 800 lbs. My plan was to use 2 x 4 planks place all around the concrete pad. So when I tilted the tank up, it could stand up but not necessarily right on the pad. I got lucky and when I tilted it, it gently slammed down but standing upright. I would use the 2 x 4's and leverage to get it centered.
Well, we were very lucky no one got hurt. I was especially careful not to have anyone around or near the Gradall when I was moving or tilting the tank...only myself. That thing is really nice and powerful.
After we got the tank upright, we had to twist it on the pad so the outlets and top door were in the right position. So what I did was use the straps around the diameter of the tank loose. Then I put three 2 x 4 planks in the strap equally spaced and started twisting them to tighten up the strap. When they were all tight, I again used leverage, with the 3 of us using the 2 x 4's pushing them into the ground at the same time. We were able to twist the massive tank exactly in the center of the slab and also with the openings facing the right directions.
Loretta took several videos of the me in the Gradall moving the tank around, but I figured LOL ... you had already seen what you needed to without cringing too much.
Hope you enjoyed THAT story as much as I did.
