3RRL
Super Member
- Joined
- Oct 20, 2005
- Messages
- 6,931
- Tractor
- 55HP 4WD KAMA 554 and 4 x 4 Jinma 284
Hi Spiv,
Thanks for asking!
About the tank, I've got a well that produces over a hundred gals a minute right next to the tank. Water will be pumped into it using a float type system. Then the tank will be plumbed using a 4" line to the fire hydrant in front of the log home.
Now, about the fire break I'm not sure. It would depend on how much forest and what kind of trees you have and also the wind factor. Out here we have almost all Oaks and they are fairly fire resistant. I've cleared at least a hundred foot radius around the home so it seems to be fairly well removed even if a wildfire rushed through here.
My guess would be a good 30' break if there was grasses and brush only ... that might work as a fire break for those things... maybe not? But a much greater distance would be needed if there were taller trees.
Oops, I didn't see Brian's post...
Thanks Brian.
Thanks for asking!
Thanks Brian.
