3rd Function Diverter pressure relief
   / 3rd Function Diverter pressure relief #21
I have seen a tool, while looking at some German forestry site, for connecting and disconnecting quick couplers. It looked like channel lock pliers with a fork instead of a jaw that fits on the coupler. Squeezing the pliers connects the coupler even under full pressure.
   / 3rd Function Diverter pressure relief #22
It is difficult to believe that an average individual can not couple the QD's if they are a matching pair, and the temp is the same as when disconnected.
However difficulty is a relative valve.
Sometimes my hands do not function well due to things like arthritis, and it is a struggle to couple the QD's.
The QD coupling should be done with engine off
As you all know. the culprit is heat causing pressure to rise, and therefore making connection more difficult.
I simply press the male QD ball on a hard surface.
If the QD is on a cyl with a load, it is very hard to couple, as there is pressure generated by the load, plus heat.
For those that are having difficulty, there are QD's that couple under pressure. Some couple under low pressure and others at operating pressure.
I have suggested a tee and an on/off valve in series with the QD to release the pressure if necessary to make things equal. A needle valve would work to relieve any pressure.
Some QD from different manufacturers work fine, and some don't.
QD's with poppet against ball type QD sometimes work and others don't.
   / 3rd Function Diverter pressure relief #23
If this has been this way all along. This is just a guess maybe the valve only lets the back pressure relief one way. It wouldn't take just a few to change the hoses around on the valve. I'm thinking the in and out ports not the work ports. This is only coming from left field, and if you are 100% sure you are hooked up right forget this.
   / 3rd Function Diverter pressure relief #24
I can't find the site with tool mentioned above but found similar tool used for installation of sleeves on PEX tubing. It is the same idea.
RAUTOOL M-light
Like I said, I took JJ's advice from earlier in the thread to finally solve it for good. I hoped the connect under pressure fittings would do it, and they do help - you get about a 50/50 chance of them working alone. When they don't then you use the pressure relief tool which is the old fittings on the piece of pipe as mentioned. That seems to break the pressure enough to solve it for sure. I decided not to do the needle valve method as I was more concerned that the valve could be left open or get knocked on during use. That method would surely work too.
Both my friend and I were totally unable to connect these fittings by hand previously. Neither of us is small or nor a weakling. The fact that it required more pressure than a bar clamp could provide is good evidence that it isn't us. I'm suite sure the solenoid is not allowing the pressure to release fully, though I don't know why. My guess is that it needs hydraulic pressure/flow to work right, so it just doesn't relieve when off.:confused3: When you apply pressure to the fitting with the bar clamp, it creates pressure in the system that then can be relieved by tripping the solenoid switch. You do that a couple times and it draws together a little bit each time until it finally clicks in (before these changes).
I know the concern with fluid heating up in the hoses in the sun. This is not the issue. All of these tests were done with the tractor in the shed with immediate disconnects/reconnects so there is no sun and no time for anything to really change and build pressure. It has to be the solenoid, I just don't know why. Maybe it is the design, or perhaps it is somehow defective, but it works just fine in use (grapple or plow angle moves like you'd expect). There is no way to connect it up wrong as it is just a pair of input ports and 2 pairs of output ports - one to the curl/dump, and one to the 3rd function. If it was connected wrong, something would either be moving backwards or it just wouldn't work at all.
I'd like to know why, as it is(was) very frustrating, but at least everything is now usable without a fight this way...
   / 3rd Function Diverter pressure relief #26
I know you guys have tried everything you can think of. Let me bring one other thing that might of been missed. I take it that you are useing the loader valve for the 3rd function. When you are moving the switch for the 3rd function just make sure you push the loader lever way to the right. 1st to the right is regen and 2nd the spool is then open to tank on dump. 1st to the right might not let the psi off of that line.
Thanks for the thought, Leejohn, but I have it done both 1st and 2nd notches on the loader valve with the same effect (i.e: none).
   / 3rd Function Diverter pressure relief #28
Ok one last thought. Is there any possibility that the valve is not getting power when the key is in the on position, and that it only gets power when the engine is running? This would be possible if there were some kind of relay that was tied into the power circuit, so that no power were able to be utalized till there was an output from the alternator. This could be a reason why the pressure would not release if the key was on when the engine wasn't running because the valve wouldn't work no mater how many times you tried to release it. Now that being said I have no idea how your valve is wired or if it was wired by the dealer or you did it, or if you have already looked at this already, but if the valve works properly when the engine is running and doesn't (to releive pressure) when its not it would make sence. Usually when something doesn't work properly and you ahve exhausted all avenues to correct it it is something really simple! :confused3:
Good thought, but not it. I wired it myself and it is a switched circuit so it is only on with the key on (engine running or not). So I always stop the engine, then turn the switch back on to activate the solenoid circuit. You can feel/hear it click, it just doesnt seem to relieve the pressure.
Thanks for tossing the suggestion out there. I appreciate it.
   / 3rd Function Diverter pressure relief #30
Well that's all I got!~
2019 Harley Davidson FLHTP Electra Glide Motorcycle (A56859)
2019 Harley...
2017 Ford F-250 (A55973)
2017 Ford F-250...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
2020 DRAGON ESP...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2016 KOMATSU D65PX-18 BULL DOZER (A58214)
2016 KOMATSU...
