3X20 Series, kinda of a letdown/relief!
   / 3X20 Series, kinda of a letdown/relief! #21
"TO me that equates to a little bit more ballast for the loader."
Throw a heavy duty box scraper on the rear and you will have ballast coming out your ears. At about 1000lbs for a 72" hanging 3 or more feet off the rear, it ballasts the loader very well and box scraps better then the light weight 72" ones. I don't bother to ballast my tires as a result. It affords better mowing performance on my hilly terrain.
   / 3X20 Series, kinda of a letdown/relief! #22
If anything, the turbo engine should be a bit more fuel efficient. Running consistently at the increased HP levels will take more fuel though.
   / 3X20 Series, kinda of a letdown/relief! #23
Weight spec appears to be the same. 2wd was 2600, MFWD 2900. New units are 2900#
I went with the larger R4 tires and plan to add 60 or so gallons of Rim Saver fluid
   / 3X20 Series, kinda of a letdown/relief! #24
I looked at 3x20s yesterday and to my dismay the tires read "Made in Serbia"
this dealer also sells mahindras and the Titan tires on those read "Made in the USA" kinda ironic no?
   / 3X20 Series, kinda of a letdown/relief! #25
Thanks to the original poster of this thread. It has made me think about my tractor and an upgrade.
I have a '99 4400 with about 800 hours. Syncreverser Trans, 430 loader, 48BH, 60" commercial MMM, assorted other attachments.
When I heard that the 20 series was coming out, my brain instantly started to think-trade, trade. Kind of like when the 10 series came out.
The first thing that I looked at was the e-powereverser. I only had the synchreverser. Wow, I wanted that. Then I looked at the horsepower-slighly less on the 10 series. Then I asked my dealer, and he kind of winced and said something to the effect that they were having a few troubles with that. Now they have went back to just the powereverser. Are they trying to tell me something?
All of the switches on the right fender. I wanted that, especially the 4X4 switch. Look at it now, back to a lever by the left foot, just like my 4400. Are they trying to tell me something?
Parking brake. On the 10s they went to I believe a lever pull below the dash. I thought that would be neat. Now I see that it is back on the left like my 4400. Are they trying to tell me something?
Tilt wheel. This needed improvement on my tractor. I have had to adjust it a couple of times. I think they probably have this figured out on the 20s, as I believe someone wrote they did not like it on their 10 series.
Engine-My 4400 has a 101 cu. in. (1.6L) direct inject. The comparable 3520 has a 91.5 cu. in. (1.49L) turbo. I will compare this to the Chevy PU line. My brother has a '98 chevy with a 350 cu. in. (5.7L) Vortec. Good heavy built truck with a good motor. Likes its fuel. Then Chevy said they could get more power out of a 327 cu. in. (5.3L) motor with better fuel economy. In the sales book, it said that it had more pull than the 350. What you had to look at was the RPMs. You had to rap them out to get the horses. Nobody puts them in neutral at a stop sign and revs them up to 4500 RPMs and then drops them into drive. So, put the same load behind both trucks and the '98 350 will smoke the newer truck.
The saying "there is no replacement for displacement" has stuck in my head since then. If you ask me, Chevy had it perfected in their '98, screwed it up in '99 and have been trying to get it back since then. My personal opinion. Does this translate into compact diesel tractors? I am not sure. My Dad has a stump grinder that will handle a 150 hp tractor that I put on my 4400. It is the 1st thing that I have attached that will make the tractor work. I would be interested in a comparison between the two. I would be willing to bet the differences would be minimal. Probably not enough to justify the price of the trade.
The loader connection points are a great improvement, the capacities are not significantly different in my opinion. Not enough to make me believe I have to trade.
I had already started to try to talk my Dad into a trade when I first learned of the 20 series. Three of us went together and bought consecutive serial number 4400s. Because it is Dad, I would not trade unless we could do that again. My brother owns a 4600 as well. I thought we could all trade at the same time and cut a deal. All of our tractors are paid off, and that is another good thing. I have found very little to justify the trade price. I would guess that it would take $10K to get it done, BH, options, etc.
Why did I write this? I am not sure-I guess the original post caught my attention, and I was really thinking trade. I am ready for all of the replies, should be interesting reading. Right now, just like Chevy, I will wait until John Deere works back to perfect again.
   / 3X20 Series, kinda of a letdown/relief! #26
If you like what you have, then stick with it. I felt compelled to wait to buy the 3720, but may be less compelled to trade had I owned a perfectly good 4000 or 400-10 series. I would definitely suggest trying out a 3520 or 3720. Throttle it up and it will sing /forums/images/graemlins/grin.gif...
Having the 4x4 go mechanical may be a good thing. There's already quite a few rocker switches to figure out. The hand brake looks like a decent idea. The pull knob/pedal thing was OK. I'll have to try it to see if the lever pulls the pedal(s) (necessitating tying them together, or if it pulls both brakes simultaneously.
Just got in from a day of loader work and trail busting with a 4310. Had a lot of fun, and until my loder comes in, I'll be using this machine for my weekend trail breaking/making...
   / 3X20 Series, kinda of a letdown/relief! #27
lcisled, I like the way you think but going back to the way it was doesn't neccesarily mean the new way was a mistake. I am referring to the 80's cuts that had the fuel tank between the dash and engine then the 870/970/1070 came along and the tank was in back and everybody said that makes a lot of sense.
But starting with your tractor series they went back to old way. /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
   / 3X20 Series, kinda of a letdown/relief! #28
</font><font color="blue" class="small">( All of the switches on the right fender. I wanted that, especially the 4X4 switch. Look at it now, back to a lever by the left foot, just like my 4400. Are they trying to tell me something?
)</font>
The primary focus in the re-design was to make the unit cheaper to produce thereby increasing margin. Same with using tires from Serbia; increases margin. The TEN series have a lot of cool features but those features are expensive for both the componets and for the labor to sub-assemble them. During the TEN Series production run process engineers examine the whole assembly process looking for parts and jobs to cut to increase margin.
I'm not sure what Deere's costs are but for GM every employee equals $2 million. That figure includes wages, benefits, retirement, workman's comp costs among other things. Reducing jobs not only cuts current costs but future costs as well.
   / 3X20 Series, kinda of a letdown/relief! #29
dmp437,
I have been following this thread because I am one of those who has been waiting anxiously for the release of the 3000 series' I am now starting to feel guilty about my desire to have this new machine, since several posters seem to be under-impressed by them after seeing them. I also certainly do not want to downgrade from my 4310, especially if more parts are imported and there exists a question with regard to their benefit over existing models. If only there were a way to turbocharge my 4310..........
John M.
   / 3X20 Series, kinda of a letdown/relief! #30
Now your not gonna tell me the accountants make better cars or tractors are you.
Thats why gm is where they are. and why Lutz is where he is now. Is he helping put product back to being first, yes, does he have total veto power over accountants no.
And do you think that union worker just gets wiped off the payroll? no just means the floors get swept a little quicker.
LMC LOT NUMBER 142 (A53084)
LMC LOT NUMBER 142...
2004 CATERPILLAR 140H MOTORGRADER (A51406)
2004 CATERPILLAR...
2019 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2019 INTERNATIONAL...
INSPECTION (A51573)
INSPECTION (A51573)
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
