4 Month Old T2220 W/Hydraulic Problem
/ 4 Month Old T2220 W/Hydraulic Problem #1
Hudstone
Hey all, I wondered if anyone has seen an issue like this. I have a 5 month old T2220 w/loader. 2 weeks ago I went up to my enclosed unheated garage and started the tractor. It was about 25 deg F. It would lift the loader and 3 point but would not steer. I moved the steering wheel back and forth and it finally started to work. Called the dealer and they came down to get it. After sitting overnight outside it did the same for them only all hydraulics were not working. New Holland recomended the all season thinner weight hydraulic oil which they did and that did not fix the problen although it was better. Then New Holldand recomended a transmission heater which the dealer installed. The dealer told me that he talked to some other dealers in our area and no one else seems to be having this problem. I am told that the T2220 has a new system that uses a common resivoir for steering and everything. It seems to me that thinner fluid and a trans heater is a Bandaid for a true problem. Any ideas/comments?
/ 4 Month Old T2220 W/Hydraulic Problem #2
I think the thinner fluid is a bandaid. I could understand the thinner fluid if it was 0deg. I dont think 25 is that cold.
Bill
/ 4 Month Old T2220 W/Hydraulic Problem #3
Hey Hudstone,
How long did you let the tractor warm up before
trying to use the Hydraulics?? In the owners manual
in regular temps it needs to run before use, on page
2-8 it gives at 32 to 14 degrees you need a 5-10 min
warm up. From 14 to -4 it needs to run 10-15 min,
colder than that you need it to run at least 15+ min.
I'll test ours out on Monday and report back.
Up here I like to let my tractors run for 30+ min
in the cold before I even try to move them.
/ 4 Month Old T2220 W/Hydraulic Problem #5
Does the T2220 not have a separate power steering pump and reservoir from the main pump and reservoir?
I just checked the NH website to make sure. The T2220 spec sheet shows to have an implement pump and a steering pump, so it would seem that the main reservoir has nothing to do with steering. The power steering pump and reservoir are independent. I'm confused why a dealer would suggest a transmission heater would solve or even effect a power steering system.:confused:
Hudstone, I just re-read your original post and it said the reservoir has been changed. Perhaps I need to dig deeper. I'm surprised NH has combined these functions into one reservoir.
Edit: Well, this was a worthless post. . .:rolleyes: I checked the parts diagram and see that there are two pumps, but the power steering reservoir has been eliminated.
/ 4 Month Old T2220 W/Hydraulic Problem #6
Hey Jim,
I'll do a test with mine on Monday, it will
be 0 degrees. I only have the block heater
in her, they do have a HYD heater but I'm not
going to do that unless I need to.
When they delivered it I asked if it was ready
to use this winter and was told it was. It has
the original HYD fluid and filter. The reason I asked
was with my DX25E I was told I had to run a
special filter in the winter.
With my IH1066, when it's cold I start her up
and I go take a brake and let her warm up some, I
have pulled her out of the shop and drove her to the
house and let her run awhile.
I love being a cold weather tester, but I hate
to disappoint you guys, I will not test this at -20:).
Thumper
/ 4 Month Old T2220 W/Hydraulic Problem #7
We'll with temps getting to -24 tonight we
decided to clean the farm today.
Had the tractors block heaters plugged in over
night. The T2220 started right up, no funny
noised, went and started my IH1066, then went
to do other work for 20 min. Temps were -2 outside
and about 18 degrees in the shop.
Pulled my 1066 out of the shop and then took a look at the T2220,
tractor sounded fine no Hyd wine. Took her
out of the shop and started to do the close in work and
get a feel for the loader, tractor ran fine, no surprises
cleaning away the snow, ran her for 1/2 hour with
no problems, put her away and did the blowing
with the IH. The first 10 min I worked her easy just
over half throttle, then I upped the throttle and
got to the hard work.
I do think in these temps I should cover the coolers
a bit to help the tractor maintain heat better. This
is going to be a fun tractor, I do need to get a ballast
box or rig some extra weight in the rear.
/ 4 Month Old T2220 W/Hydraulic Problem #8
I slip a bit of heavy cardboard in front of my radiator (TN70A)when it is subzero. I assume it keeps thing a bit warmer. The cardboard is well secured!:D
It covers around 70% of the surface area.
Bob
/ 4 Month Old T2220 W/Hydraulic Problem #9
Thanks Doc Bob,
I've got the 1066 fully covered, just have not
used this one enough, I wanted to see how she
maintained heat today, then engine did fine in
these temps I just think the HYD could use a
little cover also. I'll make a couple small covers
to put on the coolers.
Heck up here I've got everything covered:).
I did let it warm up for about 5 min. Probably should leave it go longer though. The thing that puzzles me is that the problem has slowly gotten worse and that makes me think that there is a problem. I did forget to mention that the first thing that they did was change the filter and that had no affect on the problem. I am basically comparing this one to the TC30 that I had bought new 3 years prior to this one. That tractor never missed a start and always performed well even in adverse conditions. I am concerned with the thinner hydraulic fluids performance next summer. Not sure how the heat will affect it. Any idea?
/ 4 Month Old T2220 W/Hydraulic Problem #11
We'll I need to use the tractors again,
I started up the T2220, yes it was cold out -5,
yes she wined a little so I went and took a planned
break with her warming up. The other Day my wife
and I zip stripped a small piece of carboard to the
radiator and the HYD coolers, this really helped the
use of the FEL and general movement of the tractor
today. I love this tractor!!!!!!!
/ 4 Month Old T2220 W/Hydraulic Problem #12
I used my T2320 today. 28 degrees outside, sat for the last two months in an unheated garage. Temperatures have been below feezing for the last 1.5 weeks, and 2' of snow on the ground. No issues with the hydraulics or steering. I will ask the dealer but i am sure they used the regular fluid (134?). I let is warm up for about 5 minutes. I would keep after the dealer, there may be something else going on.
/ 4 Month Old T2220 W/Hydraulic Problem #13
I am a dealer and have noticed the same thing on new machines we have on the lot. Does working the steering wheel back and forth a few times get it to start working?
It does seem to be a new issue. New Holland official stance right now is to switch to F200A oil and plug the trans heater in for four or five hours before use.
Yes working the steering back and forth several times did help initially but as the problem got worse it would not work so well. My dealer called and they said that they found a loose fitting in the hydraulic return line. I'm not sure if that would do anything or not. I have it back now and I have been trying to try it without using the trans heater. I want to get an idea if anything is better with it. It seems to be better but the steering is very slow on start up although it does steer.
I have developed a new issue as of 2 days ago. When I start the tractor it starts to idle and then the RPM shoot up to the point where if I didn't shut it down it would keep going until it blows up. This is with the throttle all the way down. If I start it and shut it down 3 or 4 times then it will idle normally. I called the dealer and he said his new T2220 on his lot is doing the same thing. He has contacted New Holland and they are trying to figure out a fix for this. They think that it has something to do with the thick cold fuel and the fuel pump. I'm not sure. Any ideas on this problem?
/ 4 Month Old T2220 W/Hydraulic Problem #15
Hudstone, do you ever want to send NH an invoice for prototype testing of their tractor? Sheesh!:rolleyes:
That sounds like a heck of an idea. I am finding it hard to feel too good about my new tractor purchase. I bought a new TC30 before this one and had great luck with it for 3 years. Hopefully this will be it for the problems.
/ 4 Month Old T2220 W/Hydraulic Problem #17
Ask CNH to refund your purchase price, since you have had so many problems, tell them if they refund you the purchase price, you will buy another CNH tractor.
/ 4 Month Old T2220 W/Hydraulic Problem #18
Hey Hudstone,
What blend of fuel and additives are you and the dealer running??? Are the T2220 at the dealer all new units??
Now you've got me thinking I better keep a eye on our
tractor.
/ 4 Month Old T2220 W/Hydraulic Problem #19
I hope they find a legit fix for this. That really sucks if you had t use it in an emergency.
Good luck all.
I have been using No. 1 diesel fuel with Power Service Products Diesel Fuel Additive. Website Power Service Products, diesel fuel additives, prevent gelling, clean injectors, disperse water, boost cetane, reduce emissions, improve fuel economy I have used this product for several years and have never had an issue so I don't think that it has anything to do with that. I'm not sure what the dealer is running for additives but he uses No1 diesel also. The dealer that I have purchased my last 2 tractors at is a fairly small dealer. He ussually only carries 2 or 3 compact tractors. At the moment he only has 1 new T2220 and that one he says has this latest issue with the high reving on startup. I have only let it go up to about 2200 rpm before I shut it down but it sounds like it would go until it blows up. I still have not heard from him if they have a (fix???) for this. Maybe I will have a block heater, trans heater, and a fuel heater when this is all done. I should at least get an electricity allowance from CNH if this keeps up. I'm not sure if there is a lemon law for tractors in Wisconsin. We do have one for vehicles though. I may have to check into it. Either way I think that I would purchase a New Holland again. Between my Father and I we have purchased 5 new New Holland tractors in the last 7 years and this is the first problem that either of us has run into.
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
2017 KALMAR OTTAWA T2 4X2 SPOTTER TRUCK (A60430)
2017 KALMAR OTTAWA...
43024 (A59228)
43024 (A59228)
JOHN DEERE 410L BACKHOE (A52706)
JOHN DEERE 410L...
2018 KOMATSU WA270-8 WHEEL LOADER (A60429)
2018 KOMATSU...
