4020 Series Specs
   / 4020 Series Specs #141
My dealer said he beleives deere will put there engines in the 110s because of the emmisions laws aroung the country. If you ever look under the hood of the 110s there is no more room for anything else so they will probably have som redisign time ahead. That is why it only has the 4610 engine it is a different block. And yes it needs the 58 hp from the 4720 mine is 9000 lbs and 43 hp is not overly powerful but it does its job.
   / 4020 Series Specs #142
More info at Deere.com
JOHN DEERE DIESEL ENGINES
* All tractors feature 4-cylinder turbocharged John Deere PowerTech™ engines that meet Tier II EPA emission standards.
* High-output diesel engines provide up to 30% torque rise.
* Direct injection provides better cold-weather starting.
* Common rail fuel system provides more uniform fuel delivery for improved performance.
* Engine oil cooler provides cooler oil for more efficient heat rejection, improved performance, and added durability.
* New high-capacity 75 amp alternator provides additional electrical capacity for accessories.
* Under-hood muffler and horizontal exhaust reduce sound levels and provide for excellent visibility.
* Six-rib poly-vee engine drive belt with automatic tensioner requires no adjusting.
TRANSMISSION
* Two transmission options are available to match customer needs:
o 12F/12R PowrReverser™ - Hydraulic reverser allows for ''clutchless'' direction changes for greater productivity.
o eHydro™ - Infinite speed selection, no clutching or shifting required.
FOUR-WHEEL DRIVE - STANDARD ON ALL MODELS
* Increases traction and pulling power.
* Shift on-the-go for greater productivity.
INDEPENDENT PTO
* Independent PTO - Operation of PTO is totally independent of the tractor transmission, allowing the PTO to be hydraulically engaged and disengaged on-the-go.
* Allows operator to select rear PTO or mid and rear PTO usage from operator seat.
540 RPM REAR PTO
* Allows operation of a wide variety of rear-mounted implements.
* PTO brake prevents PTO-driven implements from coasting to a stop by automatically braking PTO when disengaged.
MID PTO (Optional)
* Provides shaft-driven power to mid-mower and front implement.
FINAL DRIVES
* Planetary final drives distribute axle loads over larger area for extended durability.
DIFFERENTIAL LOCK
WET DISK BRAKES
* For positive stopping power and long life.
HYDROSTATIC POWER STEERING
* Standard equipment on all models.
* Provides optimum performance in all operating conditions.
OPERATOR STATION
* Clean, uncluttered design. Color-coded controls are located on either side of the operator.
* Clutch and brake pedals are designed for maximum comfort and ease of use.
* Contoured, comfortable high-back seat and scissor suspension enhance operator comfort.
o Seat suspension adjusts for weight and height.
* Flat operator platform provides for easy entry to/exit from the tractor.
* Folding ROPS and retractable seat belt increase operator safety.
INSTRUMENT PANEL
* New Performance Tracking System accurately monitors key tractor systems and functions.
o Adjustable MotionMatch™ allows tractor rollout to be adjusted to operator's preference.
o Diagnostic control center provides system status to operator and allows easy access to John Deere technicians for diagnostics.
o Digital speedometer (eHydro model only).
o Digital hourmeter.
o Low fuel level warning light.
* Large easy-to-read dials provide engine rpm, fuel level, and engine temperature at a glance.
* Maintenance-free LED indicators illuminate for air filter restriction indicator, alternator, engine preheat (glow plugs), positive 4WD engagement, oil pressure, PTO engagement, park brake engagement, and turn signal/warning lights, and cruise control.
* New starter protection circuit protects starter against grinding.
* Backlighting provides excellent nighttime visibility.
IMPLEMENT ATTACHABILITY AND COMPATIBILITY
* Implement attachment and removal is fast and easy.
* Simultaneous mower, loader, and backhoe compoundability.
1604 (A57192)
1604 (A57192)
DEUTZ MARATHON...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58214)
2013 TEXAS PRIDE...
*Selling at Royal Auction Zephyrhills, FL Location* (A59228)
*Selling at Royal...
JLG 660SJ (A58214)
JLG 660SJ (A58214)
25 DUAL AXLE GOOSENECK TRAILER (A58214)
25 DUAL AXLE...
