4310 or 4410 Help me decide!!
   / 4310 or 4410 Help me decide!! #31
</font><font color="blue" class="small">( So, if you don't mind me asking, how do you TBN'ers like your back hoes? Have any of you done a comparison between the 47 and 48? )</font>
I think they're fantastic. As to comparison, I fell that well over 90% of my use will be 8 feet deep, or less. I can't see needing the 48 for me. There are plenty of folks who will argue that they aren't worth the price. Well, I couldn't get the tractor without the hoe, (or face you know who...)
I imagine digging stumps would go faster. But I am very pleased.
   / 4310 or 4410 Help me decide!! #32
One the backhoe issue, I went with the 47. My reasons were based on how much I would actually use the hoe, and what the uses were. Honestly couldn't think of anything I would need to dig 8 ft. down for. Understood that the smaller hoe meant moving the tractor more. Neither one is cheap, but $1000 is $1000. I was already spending $29k, and I couldn't justify another grand for my use.
If the money didn't matter, I would have gone with the 48. For convenience sake (moving the tractor), and just because it's BIGGER. Looking at it now, I still couldn't justify the extra money for the 48, but have certainly made use of the 47. It's a very capable hoe. It was hard not to buy the biggest and best tool available; I usually do that. To my amazement, I have probably spent 1/4 of my seat time using the hoe. Other than cleaning up after the dogs, I haven't picked up a shovel since I bought it. /forums/images/graemlins/smile.gif
Sometimes I wonder if the 48 makes a big enough difference over the 47 for someone, maybe they should have a bigger machine all together. That is somewhat assuming they are pushing the limits regularily.
Your decision should boil down to your needs. If you plan on using the hoe quite a bit, going larger would probably be good. If you can live with the 47, go buy some more attachments.
   / 4310 or 4410 Help me decide!! #33
Absolutely agree with you,
I have been timbering on my farm and I have taken several thousand board feet of log out of the woods and all with my John Deere 4 in 1 loader. I put 8' ft logs up to 20' logs in length and from 10" diameter to 23" inches diameter and put them on a 16' trailer,the ones which I cannot lift completely off of the ground with my grapple (4 in 1) I can lift one end up and put it on the trailer and slide it on the trailer.It will make a believer outta of you.Doing this with JD 4400
I have been averaging about 750 board ft a trailer load.
   / 4310 or 4410 Help me decide!! #34
If the budget is limited, I'd suggest a 4N1 bucket on the 430 FEL, and go with the 47BH. That, in my opinion, would be more versatile than a standard bucket and 48BH. Of course both are best if you can afford them. The 4N1 feature of the bucket I use at least 25% of the time I use the bucket, whereas the additional reach/power of the 48BH is maybe a 5% to 10% plus factor in most tasks. (see attached picture of typical use).
The 4N1 needs an additional valve, which is cheaper to install when the tractor is being prep-ed by the dealer. But it is very easy to operate since it's just one more lever.
Wow, thats a nice looking set-up /forums/images/graemlins/cool.gif Is that a Curtis cab?
I asked my dealer the other day about 4 in 1's and they don't carry them (very small operation). I will most likely will not get one right now, but due to the amount of positive comments I will keep them in mind. "Hay honey, lets talk about x-mas presents". /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Thanks to all of you TBN'ers, I'm getting smarter /forums/images/graemlins/smile.gif
Waldo
   / 4310 or 4410 Help me decide!! #36
The 47 BH works great. I got mine with a used JD 4300 (only 120 hrs used that is) so I had no choice. The 47 can use the small 9" bucket that is great for trenching 4" pipe. I have also used it to pick up and position barnstone/sandstone for a retaining wall. I have dug large hole, trenches, pulled plants/trees/carried tons of items/held the old brush hog up to spray paint...and even used the bucket to wave to my children watching from the window ( that was the MOST important use!). I also used it to help tear down part of an old barn. It digs to over 7 feet. The 48 may be bigger but on a 4300/4310 the 47BH does great...and can even lift you up in the air. Happy with it...yep.
   / 4310 or 4410 Help me decide!! #37
Yes, it's a Curtis canopy. Keeps the sun and rain of me and the tractor, and only about $400.
Back on the 4N1 bucket.. If you get a FEL with a standard bucket, and then you upgrade later, you'll probably never use that original bucket again. So I justified in my own mind getting the 4N1 at the start because I'd save money not buying the standard bucket. Some rationalization, huh!
   / 4310 or 4410 Help me decide!! #38
Bebster,
I recently bought a 4210 used and I am really dissapointed, I have alot of hot air that is blown from the engine toward the open sation around your feet and also I find the transmission develops alot of heat when you use the loader and 4wd> It is like sitting on a oven. Do you have the same problems? Please respond. My email is lapmedic@yahoo.com thanks
   / 4310 or 4410 Help me decide!! #39
Did you notice this a 5 year old post? Also the 4310 and 4410 are equal to the 3x20 series today. JC
   / 4310 or 4410 Help me decide!! #40
What's the beef? Is there a problem with reviving an old thread if related to his model tractor?
2021 Bell B30E Off Road Dump Truck (A53117)
2021 Bell B30E Off...
2025 CFG Industrial H15R (A50123)
2025 CFG...
2008 FORD RANGER SINGLE CAB TRUCK (A51406)
2008 FORD RANGER...
CFG Industrial SAII100 (A50123)
CFG Industrial...
2015 Ram 5500 Versalift SST-40NE 40ft Sign Bucket Truck (A51692)
2015 Ram 5500...
2014 Ford E-350 16ft Box Truck (A51692)
2014 Ford E-350...
