4520 opinions and thoughts
   / 4520 opinions and thoughts #11
We're considering a 4720 could go into more detail on this issue? Are saying
it's a Cat. 1 tractor with too much power for Cat. 1 implements?
If you choose the right implements the problem is minimized, buy a heavy duty rearblade instead of a light one intended for a 30 hp tractor, a little judgement is required. The 4720 is a powerful yet still compact tractor and is a good choice if you need more pto hp. Other than that unless you have steep grades and or hills to climb often the 4120 will do about the same jobs.
   / 4520 opinions and thoughts #12
I had a higher end cat 1 blade that the 4520 tore apart when the tip of the blade caught an abandoned steel water line. I didn't even notice it until I looked back and saw the blade in the dirt. Then I caught an old stump with a box blade and tweeked it badly (I did notice that one). So far the cat1-2 stuff is holding up well. If you treat them nice and look at the jobs, you should be able to use most cat 1. I tend to use all the HP the tractor can provide. Current blade is a six way landpride RBT 4084, so far no stress problems.
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
2016 Ford Explorer AWD SUV (A53424)
2016 Ford Explorer...
Allmand Light Tower (Runs and Works) (A50775)
Allmand Light...
2019 Chevrolet Silverado 3500HD 4x4 Crew Cab 10FT Flatbed Truck (A51692)
2019 Chevrolet...
2015 Toro Multi Pro 1750 175 Gallon Turf Sprayer Cart (A55851)
2015 Toro Multi...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
