4520 opinions and thoughts
   / 4520 opinions and thoughts #11
We're considering a 4720 could go into more detail on this issue? Are saying
it's a Cat. 1 tractor with too much power for Cat. 1 implements?
Thanks
If you choose the right implements the problem is minimized, buy a heavy duty rearblade instead of a light one intended for a 30 hp tractor, a little judgement is required. The 4720 is a powerful yet still compact tractor and is a good choice if you need more pto hp. Other than that unless you have steep grades and or hills to climb often the 4120 will do about the same jobs.
   / 4520 opinions and thoughts #12
I had a higher end cat 1 blade that the 4520 tore apart when the tip of the blade caught an abandoned steel water line. I didn't even notice it until I looked back and saw the blade in the dirt. Then I caught an old stump with a box blade and tweeked it badly (I did notice that one). So far the cat1-2 stuff is holding up well. If you treat them nice and look at the jobs, you should be able to use most cat 1. I tend to use all the HP the tractor can provide. Current blade is a six way landpride RBT 4084, so far no stress problems.
2025 Swict 84in Bucket Skid Steer Attachment (A55787)
2025 Swict 84in...
11' CONTAINER (A54757)
2007 Amkus Rescue System (A55787)
2007 Amkus Rescue...
CATERPILLAR 631G MOTOR SCRAPER (A52706)
CATERPILLAR 631G...
NEW HOLLAND 3930 TURBO TRACTOR (A54756)
NEW HOLLAND 3930...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A55218)
2024 BCL...
