4720 with Cab - Dropped off Today
   / 4720 with Cab - Dropped off Today
Thanks johndeere_2210. It has been a lot of fun, I mean work. Getting a lot of compliments from others in the area. My dealer actually took it to a home and garden show before I took delivery - with my approval of course. It did turn quite a few eyebrows.
Did some finish mowing Saturday using a 72" rear discharge mower. Time for an upgrade. Who makes the largest 3pt rear discharge mower with the highest blade tip speed? I am looking at a Rhino FM100, with a blade tip speed of 16,700 FPM. Are there any others out there larger or with a faster blade tip speed? Does anyone make a 10' 3pt finish mower with high blade tip speed?
I was amazed today at how easily this tractor with a 400cx loader lifted a pallet of sod (2500 lbs) easily. I had to be careful because the tractor was a little tipsy (side to side), but moved about 6 pallets about 100 yards. I have held off on adding ballast to the rear tires because of not wanting to rut existing yards or graded yards while laying big sod rolls. Looks like I might need the additional weight. The 400cx is a monster. My last 4720 (non-cab) with 400x loader wouldn't even bulge a full pallet of sod.
   / 4720 with Cab - Dropped off Today #35
2500lbs....WOW!
Do you have anything on the rear 3pt? You can always buy a big heavy box blade for ballast when you need it.
   / 4720 with Cab - Dropped off Today #36
2500lbs....WOW!
I had a harley rake on the back, approximately 800 lbs I am guessing. Still needs a little more weight on the back when working with a full pallet of sod. I don't need to lift them high, just move them around a little and probably won't have to move a full pallet much. I was just amazed how easily the cab 4720 with 400CX handle the pallets after not even being able to budge them with the non-cab 4720 and 400X.
   / 4720 with Cab - Dropped off Today #39
That is amazing. I tell ya, some weight sure makes a difference. I have been putting my 5525 cab thru the paces (142 hours so far) and I still think I will upgrade my 4720 to a cab. I want to use my grapple bucket on both machines. It sounds like a 4720 cab with the 400CX is the way to go.
D.
   / 4720 with Cab - Dropped off Today #40
D.
Pallet Fees (A50775)
(2) 7' ATV RAMPS (A51248)
(2) 7' ATV RAMPS...
UNUSED FUTURE FT15J EXCAVATOR (A51247)
UNUSED FUTURE...
2019 Freightliner M2 106 26FT Box Truck (A51692)
2019 Freightliner...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A51691)
Dvorak Model 3072A...
UNUSED HURRICANE D6028 JOB BOX (A51248)
UNUSED HURRICANE...
