4wd tractor vs 2wd
Status
Not open for further replies.
   / 4wd tractor vs 2wd #141
Oh another thing, If I were going to get a backhoe, I might indeed get a 4wd model
   / 4wd tractor vs 2wd #142
I would like to also state that on a lot of older tractors, and some newer ones, the front axle raised the front of the tractor a little bit, so that the majority of the weight of the tractor is leaning back on the rear of the tractor, directing the weight transfer over the rear drive wheels. I am pretty sure that tractor manufactures are aware of these principles, but 4wd tractors sometimes just look like your getting more. I believe you can make both work for you. I believe a person can learn to be content. The video of the horse farm, now that was muddy. I still believe I would get a 2wd tractor, but one that was designed properly, Front wheel assist tractors don't appeal to me that much, but they may be better suited for some people. I mainly plan on plowing, pulling heavy oak logs. I believe I can get by with 2wd myself. I would like to bring into mind that, old timers had the option of 4wd, but the majority never got 4wd, and they probably used their tractors more the most of todays tractor operators.
   / 4wd tractor vs 2wd #143
I mean some of them are still running 1940 model 2wd tractors, every season.
   / 4wd tractor vs 2wd #144
I would also like to explain, I use to own a Kawasaki Brute Force 750 4x4 ATV, that had a front locking differiential. That ATV had ITP Wheels, and Tires. The Tires were 26 in Mudlite XL's If your not familiar with them, then you can check them out, that are similiar to AG tires in tread design. When I would go offroading, through mud, over logs, up steep hills, over rocks, etc.. 4 Wheel Drive would have be the appropriate thing to have. 2 Wheel drive, would have been real difficult to take a lot of places I took it. The thing with an atv though, it is not a tractor. It isn't designed like a tractor, it has 4 equal tires, with a mid engine design, that places an evenly distributed weight over all 4 tires. It was effective in muddy conditions etc.. I have 4 wheel drive Toyota Tacoma pickup truck. I drive in 2 wheel drive 98% of the time. My truck could serve every need I have basically in 2 wheel drive, but 4 wheel drive does come in handy in the winter, and other situations, It does. I expect to use the 4wd in it though like that. I have taken it off roading by the way. If you know the topography of Southern West Virginia, yes there is plenty of steep mountains to climb, mudding, and off roading, etc. I have seen some video's of people take 2 wheel drive Fergies off roading, that seemed to get by ok. I don't reall plan on doing that, but my point is for what I plan on doing, 2wd will likely work best for me. If I get stuck in the field, I will likely be able to use my pickup truck to pull it out.
   / 4wd tractor vs 2wd #145
   / 4wd tractor vs 2wd #148
The Massey Ferguson 2605 is priced about $12,000.00 The 2650HD would probably be about $22,000.00 The 2625 maybe somewhere around $19,000.00 The NH T4020-t4030 I am not sure, I wouldn't pay anymore than $19,000-$22,000 though. The Farmall 70 is about $19,000.00 new. The John Deere 5045d is about $12,000.00, there prices don't include any implements, or attachments of any kind either. I am considering a good plow. I have looked at Kuhn's Master 102 2 bottom Reverse Roll Over plow, but I don't know the price of it. It is probably quite pricey. I looked at some used Massey Ferguson #43 plows, 2 bottom. I would like to find a good 16 in one bottom plow though, if I could find one. I looked at the King Kutters, Howse, Leinbach, ETA, County Line, Frontier, and some others, but I wasn't too impressed with the quality of the metal they seem to be made out of. Kuhn has some moulboards, and plowshears made out what appears to be high quality steels. I considered ordering them, and building my own plow. Leinbach line seems a little better than the rest of the ones I mentioned though. ETA is working on a full size plow. I don't know when they will have it available. I have been looking for some older reconditioned plows. I believe those may be one of the better routes to go, if not. I can build one I suppose.
   / 4wd tractor vs 2wd #149
I'll also need a rotary cutter, rotary tiller, cultivator, maybe a gardenbedder. I plan on raising wheat, so I will need some kind of grain harvester, and stuff. I located an old Allis chalmers grain harvester, but it would need some reconditioning, though it works. I will also be looking for a manure spreader, and a seeder too. I have considered Kuhns rotary tillers, they appear to be about the best availabe for around my size of tractor. I looked at King Kutters pretty closely too. I'll have to be sort patient with all of this, I don't want to go in debt or anything. I plan on getting the plow,rotary cutter, and rotary tiller first. Then the grain harvesting equipment, whatever I find will work. I will likely go with a used manure spreader, that I will likely have to restore too. They are just so expensive for what they are. I found an old New Idea, that is in my State, that looks pretty good. It could use a new paint job, and some work, but it was only about $1,500.00 I think. It may have been more than that I don't recall. The grain harvest pull behind type, was about $6,000.00, that isn't including anything invested in it, to restore it for work.
   / 4wd tractor vs 2wd #150
2+2 = (select the correct answer please) 5,17,39.-3, 58,-27,329 :confused2:
4wd TLBs have a counter weight on the front to balance the extendahoe. The same TLB without 4wd will still have the front weight(about 800lbs) to balance the extendahoe. 4wd/2wd without the extendahoe will have a metal plate to fill in the front, to make the front look complete.
Status
2013 FREIGHTLINER CASCADIA 125 DAY CAB (A52141)
2013 FREIGHTLINER...
2010 KMC 3376 Peanut Combine (A52128)
2010 KMC 3376...
(3) UNUSED FUTURE JUMPER CABLES (A51243)
(3) UNUSED FUTURE...
2024 Isuzu NRR 24ft Box Truck (A50323)
2024 Isuzu NRR...
BANDIT 2550 50HP WHEELED WALK BEHIND STUMP GRINDER (A51242)
BANDIT 2550 50HP...
Land Honor Skid Steer Bale Spears (A50515)
Land Honor Skid...
