N80
Super Member
ovrszd said:N80, I bow to your superior knowledge and experience.
I knew you would, it just took longer than I thought. ;-)
RayH said:I dont dispute what your manual says, I do dispute the wisdom of what it says (or doesnt say). Problem with that? Do you now see and understand that the front end needs to turn a different RPM than the rear when turning or you will get some amount of scrubbing?
RayH said:As far as Im aware, Kubota doesnt offer this on their compact tractors. I could be wrong though. Maybe you got the first one.
RayH said:After rereading my posts, I apologize for my smarta$$ comments, Im trying to cut back but its not easy. The real point of the post was to educate, not berate.
Timber said:If you use a loader for anything regardless of the application and not use your 4 wheel drive is just foolish. The moment you put wt into the bucket or on forks you pivot over the front axle and take the load off the rears and if your front axle is free wheeling your in trouble.
N80 said:No big deal. I don't take any of this personally. I think what I react to most in these sorts of discussions is concrete, blanket statements that might not apply to everyone. That and a certain smugness (not you) that presumes there can only be one side and that all other thoughts are either hardheaded or ignorant.
My tractor has a 4wd indicator light on it and also one for the parking brake. LOL my problem is I've driven off many times with the parking brake still on.dfkrug said:I like that. But why not have a dashboard light that says "MFWD off"?
tydp said:I better take my loader off my 2wd M5400 immediately and sell it. If not, I am a fool and in great danger!!!!
Quote: N80, I bow to your superior knowledge and experience.N80 said:Well, the 'picture' offered as proof (of what I'm still not sure) is pretty much a stick figure showing that the outside front travels farther than the inside front. I'm not sure that has ever been a point of dispute.
But the thing is, Ovrszd, you're acting like you are privy to some special rule that applies to all CUT's and yet, when I've explained how my owner's manual reads and how my tractor works, you've made excuses and made up mythical systems that it doesn't have in order to shoe-horn your idea into a shoe that it does not fit.
The front diff on my tractor, most I'm assuming, is open. Only one wheel gets traction so binding is minimal except in tight turns. As I've told you, there is no binding that I can feel, not in tight turns or otherwise. There is no chatter. There is no feedback in the steering wheel. NONE. There is NO change in turning radius. So is there _some_ binding? Certainly. Of course. Is this likely to be a problem over the lifetime of my tractor? Of course not. It was made with 4wd. It was made to use 4wd. It was made to last as long as the rest of the tractor.
I'm not sure where you come off assuming that those who take your advice are wise and that those who do not are somehow dangerously hardheaded.
I've read my owner's manual cover to cover. It includes such wisdom as pointing out that diesel fuel is flammable, and yet it includes NONE of the wisdom that you can't believe that some of us won't accept. And this isn't some former Soviet block Yugo-trac, its a late model Kubota.
So if your advice is so rock solid, why doesn't my manual say anything? Why doesn't it warn that the front driveline is weak and must be handled with care (remember when you implied that the front drive line was a weak link?)? Why doesn't it say to take it out of 4wd when not needed? Why doesn't it say to take it out of 4wd even when on pavement? And no, it doesn't have some special (mythical) anti-binding system. Its about as basic a machine as anyone makes.
All I've said is to follow your owners manual. If that sounds hard headed, tell me why.
