4x4 Question
   / 4x4 Question #171
I must admit that I have not measured the turning radius of my L4400 with a tape measure. I've driven it around in a circle with and without 4wd and the tracks in the dirt look the same. In that regard I cannot claim accuracy down to the inch. The 36" difference on the Mahindra is a big difference and would have a practical impact on how the tractor was used in tight quarters. I can assure you that there is no practical difference on my L4400.
I _can_ measure it down to the inch, but don't really see myself doing that anytime soon.
   / 4x4 Question #172
Here's a simple test that all can do with tractor or truck.
On a concrete slab, steer full to one side and slowly drive in an arch in 2wd. Repeat in 4wd. Observe results. Same thing happens on dirt, it's just more forgiving.
   / 4x4 Question #173
I'll step out on a limb and admit that there is positively no way in (you know where) that I'd ever even consider purchasing a 2wd tractor if I needed to use it for loader work. I've been there, done that, got the T shirt, and it flat out stinks; end of story. Where I live, you'd have a better chance selling ice to an Eskimo than you'd have selling 2wd tractors with loaders on them. If you have one with a loader, I assume you can make the best of what you have, but it is so inferior to using an FEL with 4wd that it's even silly to compare. I've run teeny tiny tractors and I've run end dumps with a 15 yard bucket, and everything in between. They all basically work the same way. You can put an FEL on a 2wd tractor, but you will not be able to do anywhere near what you can do with a 4wd tractor.
It's simple physics. You take the weight off of your drive wheels and you have little to no traction. You can counter weight the heck out of the rear, but then you have a very unbalanced tractor if your bucket is empty. The worst is trying to use an FEL with a 2wd tractor on any incline. Now, that is dangerous. To simply pull, a 2wd tractor will generally do fine unless you are in sloppy conditions or you need to pull really hard. Then it becomes an issue when you are just pushing non-working front wheels through the muck as well as pulling your load. I've gotten more than my share of wheeled as well as track driven tractors stuck.
When you get into the class where you really need to pull hard in commercial applications, like pulling a pan behind a tractor, there are basically no more 2wd tractors in use anymore. They are all 4wd and now several are on tracks. I have pulled a 10 yard pan behind a Case IH STX450, which has tracks on each corner, and pulled the same pan with their older 450 hp Case tractor that has duals on each corner. On firm ground, they seem to pull about the same. On soft soil, the tracked STX pulls quite a bit harder. I also managed get a D11 so buried in the mud that you open the cab door and just walk out on the ground that is even with your door bottom. That's when you're really stuck!
   / 4x4 Question #174
Well I'm just here to argue with everybody! I think this post has gotten so long that people aren't reading the middle part. And believe me, I understand the value of 4wd when using a loader. It is easy to see how limited it is when the front drive line isn't engaged.
BUT, you've made a blanket statement that simply can't cover the wide range of applications a FEL can have. I'll repeat myself again (x4). My B-I-L has two large JD tractors that have FELs and are 2wd. They are both 6 cylinder machines, no idea what HP. But, he almost exclusively moves hay bails and scoops cotton seed, calf feed and rarely a bit of gravel. 4wd would mean nothing to him in these applications but more money spent against his very narrow bottom line (I don't know how anyone makes money selling beef calves).
So sure, 4wd greatly enhances the ability and range of uses for a FEL, but it hardly means there are no legitimate uses to be found on 2wd tractors that fit a given job perfectly.
   / 4x4 Question #175
Well, I'll argue too. He may have made a blanket statement, but the one you quoted isn't it. In that statement, Dargo expressed his personal feelings and used "I' three times. Hardly a blanket there.
   / 4x4 Question #176
So you think that when someone comes on the internet and tells you what _they_ would do and what _they_ wouldn't do that they are really just talking about themselves? You don't think there is any chance they might be suggesting that they are somehow correct and that those who are reading what they posted might benefit from their opinion? Come on now. When someone says, "this is what I think" they are telling you what they think is true. Otherwise, why post at all?
   / 4x4 Question #177
tydp said:
I better take my loader off my 2wd M5400 immediately and sell it. If not, I am a fool and in great danger!!!!
I haven’t been in this thread in several days; I stand behind my opinion 100%. Give me a break hear, this thread is about 4 wheel drive tractors & my opinion & comment is applied to the subject on the table and does not apply to your 2 wheel drive tractor. How can you take a comment somebody makes and take it out of context and then be sarcastic about it. It is the same thing if you have a 4 wheel drive vehicle and take it out in a snow storm and leave it in 2 wheel drive and go into the ditch, you’re a fool because you chose not to use your 4 wheel drive. The same scenario and you have a 2 wheel drive vehicle and the same thing happens, the difference being you didn't have the option. I know it is a blanket statement but we all know there are exceptions to every rule. Do we really need to make disclaimers to every statement we make?
Originally Posted by Timber
If you use a loader for anything regardless of the application and not use your 4 wheel drive is just foolish. The moment you put wt into the bucket or on forks you pivot over the front axle and take the load off the rears and if your front axle is free wheeling your in trouble.
Yesterday 01:06 PM
   / 4x4 Question #178
Exactly. That's what they think is true. Saying 'this is what I think, and here's why' is entirely different than saying 'you're wrong'. Stating opinions, particularly when qualified with 'I think' opens discussion. Blanket statements like 'everybody else is wrong if they don't think the same way as me' closes discussion. If you're looking for something to be offended about, you'll always find it. If you just read and accept what was actually said you will usually get the message intended. Remember, communincation involves three things: What was said, what was meant, and what was heard. Most of the problems we have are based on those three being different. Personally I prefer to take things literally rather than guess at hidden meanings.
   / 4x4 Question #179
To be fair, the original poster, in post #1 did ask about operating his tractor w/ loader in 2wd mode...
Soundguy
PS.. to inject a bit of 'guessing' here, in reference to this quote:
I believe he was merely trying to state that a tractor that is 2wd, and equipped with a loader, -can- handle certain tasks fine. Due to the vast possibilities and ranges of use and environments we all work and play in.. it's quite possible to use a 2wd/loader tractor to do many tasks suitably. For instance.. on pancake flat ground lifting hay bales on a front spear... that sounds pretty safe to do with a 2wd.. .. I'm not sure what other benefits a 4wd would offer in that situation.. except to line the pocked of the selling dealer.. There are many such situations that could be thought up where 4wd added no benefits, or lowered benefits. I think we all realize that there are also plenty of situations where 4wd offered many more benefits, including safety, again.. based on environment and task.
Timber said:
Give me a break hear, this thread is about 4 wheel drive tractors & my opinion & comment is applied to the subject on the table and does not apply to your 2 wheel drive tractor. How can you take a comment somebody makes and take it out of context and then be sarcastic about it. ?
Yesterday 01:06 PM
   / 4x4 Question #180
This nice long thread was getting dull. Dull is no fun. Now people are talking again. :) Hey, I've never been known as a person who is afraid of a bit of debate now and then, have I? ;) I don't know how to be PC...
And, I'll admit that I spend 80% of the time in 2wd with my tractor anyway. It's just that 20% is really needed for me. Therefore, you can say that, yes, I do have a 2wd tractor 'most' of the time, but personally I could never get by losing out on that 20% or so of use.
2016 Ford Fusion Passenger Car, VIN # 3FA6P0G79GR191653 (A50324)
2016 Ford Fusion...
UNUSED FUTURE MINI EXCAVATOR ATTACHMENT SET (A51244)
UNUSED FUTURE MINI...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2016 SDLG L948F WHEEL LOADER (A51242)
2016 SDLG L948F...
2015 Ottawa Yard Spotter Truck - Cummins Diesel, Allison 6-Speed, Hydraulic Air Fifth Wheel (A52128)
2015 Ottawa Yard...
