54" JD 300 series plow on JD 2305
   / 54" JD 300 series plow on JD 2305 #11
Nick,
I just purchased a 2305 and have the same blade and would like to use your mounting configuration. Have you found the additional bracing adequate after using the blade?
Thanks for your time. jg
   / 54" JD 300 series plow on JD 2305 #12
I know its an old thread, but I was wondering what you ended up doing for hydraulic lines? I have a 54" power angle off a 322 and need to get or make new lines to get back to the 2305 hydraulic connections.
   / 54" JD 300 series plow on JD 2305 #13
Welcome to the neighborhood.
Give your friendly JD Dealer a call, there may be a "kit" to do what you want to do. Reroute the old hoses and screw on a short hose making it long enough to reach the quick coupler.
   / 54" JD 300 series plow on JD 2305 #14
I called my Two of my "friendly" JD dealers. One quoted me around $300 for the lines and fittings off the plow built for the 2305. Not kits to upgrade either. The other suggested I see if the fittings on the current lines would work with my tractor and have new lines cut. They do fit and I will be having new lines made. Im having the bracket fabbed at a local welding shop and a local shop where I used to work will be making the lines for me.
If you look back at one of my previous posts to this topic you'll see that I scrapped the whole thing after I bought my front snowblower. I adapted the blade to the QuickHitch that Deere uses for the snowblower. That way I can switch between the blower and blade very easily.
I eventually gave the bracket I made to someone else on this forum that asked if I had a template for the parts I made. It was just sitting on my scrap metal pile so I was glad that someone could put it to use.
I still needed the longer lines that I had made up at my local Napa parts store. This was not the cheapest way to get the lines but they were the only place open when I decided to do this on a Sunday.
   / 54" JD 300 series plow on JD 2305 #16
I got my hoses today and hooked up to the plow. Everything works great, now I just need my bracket back from the welder. I did notice that my trans fan was gone while I was working on the machine today... I did not want to find that oh well. Parts on the way looks like and exciting fix.... I have found a few posts around I think I'll try dropping the drive shaft.
   / 54" JD 300 series plow on JD 2305 #17
Heres what I did:
I made a cardboard template based off of a tracing from the tractor the plow came off of. I believe it was a 322.
I had originally asked a local weld shop to make the bracket for me but he could not get steel for me in a timely fashion without charging me more for shipping so I had a friend who is quite handy tackle it for me. In the process he buggered up the hooks with the plasma and he had a friend who owns a CNC plasma table make reinforcements for the hooks and the upper holes. Here is a pic he sent me showing where the reinforcements would go:
Here is a picture of the pieces as they came out of the box. Apperently his friends company includes cookies with their products:
LiquidIronIndustries
Here is everything just about done:
He welded a tube across the bottom for strength and welded nuts onto the side for the braces:
Heres a test fit on the tractor. Note the bolts threaded into the nuts welded to the side of the frame:
The diagonal braces are a shallow C chanel I got at TSC for a few bucks. They are nice and strong and dont interfere with the steering. I had originally wanted to use angle iron but saw this today while getting bolts and it seemed like a good alternative.
It moves stuff that I have piled up around the driveway quite well. Now I need to get some snow to see how it really works.
2022 John Deere 1025R (A53317)
2022 John Deere...
2007 Mitsubishi Fuso FE84DW Crew Cab Landscape Dump Truck (A56858)
2007 Mitsubishi...
2017 Autocar Xpeditor T/A EZ-Pack 40Yd Front Loader Garbage Truck (A56858)
2017 Autocar...
LOT: (3) NEW Hi-Run 26 x 12.00-12 Lawn & Garden Tires (A59076)
LOT: (3) NEW...
2022 Ram 2500 4x4 Crew Cab Service Truck (A55852)
2022 Ram 2500 4x4...
2018 John Deere 470G Hydraulic Excavator (A56857)
2018 John Deere...
