60" Deck blade alignment
/ 60" Deck blade alignment #11
Re: 60\" Deck blade alignment
JWE,
You are right on the mark. Without a "timing" belt or gear driven system the blades WILL NOT stay in the same relative position. That's okay though because they don't need to. They are turning fast enough to ensure proper balance and discharge no matter what position they are in.
/ 60" Deck blade alignment #12
JWE,
/ 60" Deck blade alignment #13
Scrounger - The manual for my RCK-24B has a Figure G-3542 in the "Blade Replacement" section. The figure shows an underside view of the deck with blades that are numbered 1, 2, and 3. There are arrows from blades 1 to 2, 2 to 3, and 3 to 1. I understand this figure to be showing the recommended reinstallation of blades from one spindle to another after sharpening. In other words, after resharpening, reinstall the blade that came off spindle 1 onto spindle 2; the blade that came off spindle 2 onto spindle 3; etc. I don't think the angular orientation of the blades in the figure has any significance. You will need to identify each blade with a paint marker or some other method. Rusty /forums/images/graemlins/smile.gif
/ 60" Deck blade alignment #14
/ 60" Deck blade alignment #15
That's the way I understood it too, Rusty. Although I had to read it twice to be sure.
/ 60" Deck blade alignment #16
/ 60" Deck blade alignment #17
It's like rotating your tires. I have an old engraving tool that I use to engrave a number on each blade. I put the number on the back side of the lift (doesn't seem to cake with grass there). When I remove the blades I note the number of the blade and it's position. When I sharpen and reinstall I make sure I rotate the blades.
I have a feeling that this process doesn't add much to the life of the blade but I do it anyway!/forums/images/graemlins/smirk.gif
John
/ 60" Deck blade alignment #18
John
2019 FREIGHTLINER M2 4X2 26FT CDL REQUIRED BOX TRUCK (A59906)
2019 FREIGHTLINER...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55315)
NEW HOLLAND 706 30...
More info coming soon! (A56858)
More info coming...
Case CX36B (A60462)
Case CX36B (A60462)
2021 Ford Mustang Mach-E AWD SUV (A59231)
2021 Ford Mustang...
2021 TAKEUCHI  TB260 (A58214)
2021 TAKEUCHI...
