6420/640JD loader joystick won't operate
   / 6420/640JD loader joystick won't operate #1
Carmen
Dunseith, ND
6420 JD/640 JD loader
The tractor & loader has only 800 hrs. And the joystick will not operate I'm stumped please help
   / 6420/640JD loader joystick won't operate #2
If it "will not operate" as in "joystick will not move" you have moisture frozen in the cables or some other problem with the cables.
   / 6420/640JD loader joystick won't operate #3
Simple question... Is the lock lever in the operate position? It's located low on column that holds the joystick.
It's easy to bump to lock ...
I thought about that but gave the guy a little credit. :)
This joystick is ,electronic not manual. The stick is in the console.
   / 6420/640JD loader joystick won't operate #6
I see. Sounds like you need to check fuses and possibly call a dealer.
   / 6420/640JD loader joystick won't operate #7
HANGCHA CPCD25-XW98C-RT4 STRAIGHT MAST FORKLIFT (A51406)
HANGCHA...
2002 Ford E-150 Passenger Van (A51692)
2002 Ford E-150...
2017 Ford F-350 Crew Cab Service Truck with Liftgate (A51692)
2017 Ford F-350...
Ford Tractor (A50120)
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A53473)
2017 KINZE...
